UnicornBadger5
Results 1 to 11 of 11
    Aug 2010
    17
    Post Thanks / Like
    Audi A3 8P Stereo help
    Hi all,
    I've been out of car audio for a while (6-7 years) and am looking to replace the stock system on my wife's 2005 8P 5Dr A3 with something not too over the top. I used to have a top of the range Eclipse HU, Eclipse amps, Focal speakers, Nakamichi sub & sound deadening in my old car - dont want to go anywhere near there for this car!
    Must have for the HU:
    1) single DIN
    2) mp3 playability
    3) ipod control from the head unit
    4) front USB.
    Dont want:
    1) Sub
    2) To amp the front or rear speakers (hmmm tempting though)
    Hard to nominate the total budget as I'm new to the UK. Maybe around £2-300? Let me know if this budget is way too low!
    Would appreciate any advice on:
    Head unit change - do you need a fascia and any special wiring? (I have a single DIN Audi concert)
    Front and Rear speakers - sizes of stock system and any recommendations for middle range speakers.
    Thanks!
    Jul 2009
    20
    Post Thanks / Like
    I've just bought and fitted (with help from AndyMac and Slappy) a JVC KD-R821BT. features:
    Single Din
    MP3/WMA Playability
    iPod/iPhone mode, via front USB (also charges)
    Additional USB at rear, Front Aux.
    Also has the added benefit it of Bluetooth Calls and Audio streaming via A2DP, if your iPod/iPhone is Bluetooth compatible
    Although not OEM looking, the unit isn't as ghastly as some Sony HU, and you can customize the colour of button lights and the display in order to match the interior of the car, so doesn't look out of place.
    It has internal amp, so you don't need a separate one.
    You will need, depending on what's already in your car:
    -fascia adaptor
    -amplified aerial adaptor (pc5-90)
    -a cable to connect to rear speakers (pc9-404) or you can just plug directly into them from HU (will be doing this in the future when I get time).
    Total cost for all this -£140.
    Even though the Audi concert is single din, it's slightly wider than normal. Have not a clue about replacing speakers though!
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    The fronts are 4" components with 1" tweeters
    The rears are 6.5" coaxials
    The fronts can be replaced with 5.25" components but depth is limited to approx 55-60mm
    You need fitting adapter rings for all speakers. The plastic ones are rubbish, search for "Audi MDF" on ebay for my MDF alternatives
    Alex Turner
    Aug 2010
    17
    Post Thanks / Like
    Quote Originally Posted by AndyMac View Post
    Thanks... Didn't realise the fronts are so small!
    So from what I've researched the following should fit:
    Focal 130V1 - height 56.3 from base of magnet to mounting surface (+5mm of protrusion beyond the mount)
    Focal 130A1 - height 55.1 (+5mm of protrusion beyond the mount)
    Focal 130PS - height 56.5 (+10.5mm of protrusion beyond the mount)
    See tech digrams:
    http://www.focal.com/files/ft-ps1301.pdf
    http://www.focal.com/files/fiche-technique-130v1.pdf
    http://www.focal.com/files/fiche-technique-130a1.pdf
    Would you need to cut any plastic or just fit a MDF ring to mount them?
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    You need a custom MDF adapter specially for the A3. Those last 130PS components protrude too far beyond the mount and will foul the adapter as you only have 9mm clearance at the front.
    No plastic needs to be cut but you will need some Dynamat or similar
    Alex Turner
    Aug 2010
    17
    Post Thanks / Like
    So if I have 9mm of clearance at the front wont the first 2 fit (the ones with the 5mm of protrusion out the front)?
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Absolutely
    Alex Turner
    Aug 2010
    17
    Post Thanks / Like
    oops my bad, just re-read your reply!
    What does a CAN-BUS adaptor actually do and is it necessaryb? I've heard it's quit costly ~49 or so
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    All it does is provide an ignition on 12v supply which all aftermarket HU's need, and the illumination feed, which dims the HU lights when you dim the dash lights. So it's definately not needed
    Alex Turner
    Aug 2010
    17
    Post Thanks / Like
    Ok so without it the HU would have no power when the the car key is set to the first ro second click (ie the engine hasn't started but power still runs through the power windows and car fan etc) with out a CAN BUS?
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    No without it you have to run both feeds off the perm live and turn the HU on/off manually. Or you wire in the ignition feed from the fusebox
    Alex Turner
  1. Audi Stereo
    By I oOEddOo I in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th June 2010, 09:41
  2. audi s3 stereo
    By madsad1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2010, 12:09
  3. Difference in STD Stereo and BOSE stereo & Sat Nav
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2005, 17:15
  4. 88 Audi 80 stereo removal
    By imported_elmotactics in forum In-Car Entertainment
    Last Post: 15th February 2005, 05:30
  5. car stereo ariel adaptor to fit normal DIN stereo?
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 15:36
