VAG CheckBackdraft Motorsport
Results 1 to 13 of 13
    Jul 2009
    20
    Post Thanks / Like
    JVC HU Install and wiring help needed!
    Folks - need a bit of help -
    Have bought a JVC Head Unit to wire into my Audi A3 2005 (iso, single din, audi concert ii).
    I am getting power and sound from the front speakers, but not the back. The radio reception is non-existent at the minute.
    So I purchased a PC9-404 to connect to the rear speakers, but there's an extra blue lead that doesn't connect anywhere.
    I also purchased an amplified antenna adaptor - again, there's a blue lead that i don't know where to place.
    If anyone can make sense of the picture i have attached and where I'm going wrong then it'd be much appreciated!
    S
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Both blue flying leads need to be connected to the power antenna or "remote on" from the JVC. This provides the 12v trigger to turn on the rear amp and the aerial amp.
    Alex Turner
    Jul 2009
    20
    Post Thanks / Like
    Cheers Andy - there's a blue lead coming out by itself from the jvc iso harness, but its marked "steering" - is this it? I can't see anything else! sorry for being stoopid!
    Jul 2011
    172
    Post Thanks / Like
    Quote Originally Posted by stephanbegley View Post
    Run a test meter on it to see if it goes live when the head unit is switched on, if it goes live, then that's the one.
    The power antenna lead is normally blue and labelled ATT or Attenna.
    Jul 2009
    20
    Post Thanks / Like
    Quote Originally Posted by AndyMac View Post
    Right, just came across an extra iso lead that came with the PC9404, like a iso lead extender.
    Can actually see a blue cable marked "remote antenna".
    If I pull this from the correct end of the box, can I simply attach the two flying blue leads to the end of it? Or do I have leave it in place and splice them in?
    Cheers Andy and Slappy btw!!
    Will get another look at this tomorrow!
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    No it won't be that. It will be a blue with a white stripe labelled power antenna
    Alex Turner
    Jul 2009
    20
    Post Thanks / Like
    Thanks again for bearing with me.
    Theres no wire coming out of the HU like that.
    Ive taken a photo of the installation manual - sorry its a little crumpled! Its a JVC KD-R821Bt by the way! I'm looking at A5....
    Jul 2011
    172
    Post Thanks / Like
    It's A5 (Blue with white stripe on it). this is your remote lead/power aerial which is the power antenna lead.
    Jul 2009
    20
    Post Thanks / Like
    Cheers Slappy! Nearly there! Again, do I have to splice the two leads into that a5 cable or should I just pull it from the box and clip them on?
    Also, should I attach them to the end closest to the HU, or the end farthest away, if you understand my meaning?
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    I was gonna say what part of "power aerial" didn't you understand? LOL
    Yes, any of those methods, length is irrelevant. It is just a very low power 12v trigger, nothing more.
    Alex Turner
    Jul 2011
    172
    Post Thanks / Like
    The end of that wire should be taped off, remove the tape and connect the other two wires onto it.
    Jul 2009
    20
    Post Thanks / Like
    Cheers Slappy/AndyMac, am pretty much sorted now.
    That blue/white wire was wired in to the JVC power harness, it wasn't free or had no name on it.
    I guess I was frightened of tearing up the wiring! I ripped it out of the ISO connector and clipped the other two wires into it.
    However, not very impressed with the rear speakers when set against the JVC amp, really really low!
    I think I'll have a look in the future as to connecting directly to rear speakers, but for now it'll do...
    AM reception and FM reception now perfect. Thanks again for your help and guiding me through this!
    Jul 2011
    172
    Post Thanks / Like
    Unfortunately your rear speakers are powered by the puny Audi amp but the fronts are fed directly from the aftermarket headunit, hence the difference.
    I'm in the same boat, I'm going to run new speaker wires directly into the rear speakers when the weather improves.
  1. Help needed with an electrical issue. (Wiring Diagram needed)
    By Wiganer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2011, 10:48
  2. RNS-E Mk2 Install - what is needed?
    By jsh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2011, 13:53
  3. Wiring in a proper accessory feed (ignition on) for aftermarket HU install
    By AndyMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th November 2010, 20:09
  4. what is needed to install FBMFSW?
    By a3_sline_tdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2010, 08:56
  5. Phatbox install disappointment - help needed
    By wingdiver in forum In-Car Entertainment
    Last Post: 22nd May 2009, 08:39
