W8 PerformanceDPM
    munchkincoupe's Avatar
    Aug 2010
    590
    Post Thanks / Like
    £80 for HU install?
    Just been quoted £80 to fit Sony DSX-S300BTX into my A3 8P with the single DIN Concert II with ISO fitted
    The fitting company said " You've got an active system so you will need a module for all speakers to work with the Sony unit.
    The price for the module , antenna and installation = £80"
    Does that sound right for parts needed and fit price?
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    You need a wiring adapter, antenna amp adapter and fascia plate which all in is about £25-£30, and half an hours labour. £80 is a bit steep unless that includes a CANBUS emulator to give you auto switch on/off with the ignition, which is unlikely as they are around £55 just for the part.
    Alex Turner
    Aug 2010
    590
    Post Thanks / Like
    Got it done for £60
    Jan 2012
    Hertford, UK
    95
    Post Thanks / Like
    How does it sound?
    Have you kept the stock speakers?
    Nov 2011
    South Yorkshire
    134
    Post Thanks / Like
    Are you also having to fade quite a bit to the rear to get the hear the rear speakers. What settings have you got it on to get it to sound perfect?
  1. MY first install
    By frumpy_pigskin in forum In-Car Entertainment
    Last Post: 10th January 2010, 19:30
  2. HU and Sub Install
    By thejoose in forum In-Car Entertainment
    Last Post: 12th April 2009, 23:48
  3. A4 install
    By slight_problem in forum In-Car Entertainment
    Last Post: 17th September 2007, 16:32
  4. My Install
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th May 2007, 15:52
  5. NEW INSTALL!!
    By imported_AudiAuto in forum In-Car Entertainment
    Last Post: 2nd September 2004, 12:45
