Adrian S FluxDTUK
Results 1 to 7 of 7
    Nov 2007
    HULL
    54
    Post Thanks / Like
    Symphony II & parrot MKi9100
    hello all,
    I have read a lot of threads regarding the installation of parrots, but I'm getting more and more confused.
    I have a 2006 A3 2.0T Q S-line. It has a double din symphony 2, its a 6 disc changer as well, all the speakers are Bose...but there is no sub/amp in the boot? is this normal, and my question is , if i fit a Parrot MK 9100 will i need any other cables/mods to get it working through the Bose side of things as I've read about it using just the parrot amp and not the audi/bose stuff when streaming music...
    sorry if this doesn't make sense, any help would be appreciated.
    thanks ben
    Current -Lava Grey, A3-8P2, 2.0 TQS-Line - Few extra bits and bobs
    Mondeo - Gap between real cars
    Audi A3 - Black- 1.6 sport- 17" RS4's - Gone
    Dark times of Vauxhalls.....
    s8craig's Avatar
    Jul 2005
    Manchester
    1,101
    Post Thanks / Like
    It must have an amp, all Audi HU's have either a 2 channel amp (non bose) or 4 channel for BOSE. It's just built into the sub in an A3.
    My Retrofit Website
    http://www.tclsatnav.com
    Nov 2007
    HULL
    54
    Post Thanks / Like
    Thanks mate, i have look in the boot and my old A3 had a compartment with sub/amp. But this one has all bose lab led up speaker grills, says bose when you turn the stereo pn. but there isn't a sub in the boot, well i can't see a access compartment...or isn't there one?
    thanks ben
    s8craig's Avatar
    Jul 2005
    Manchester
    1,101
    Post Thanks / Like
    It's hidden, no access compartments. Just checked, the A3 non BOSE it's in the SUB, but the BOSE does have a seperate BOSE amp.
    My Retrofit Website
  6. Thanks bendhamrait thanked for this post
  7. #5
    Nov 2007
    HULL
    54
    Post Thanks / Like
    thank you i appreciate that, stopped me being as confused !
    just a question of do i need any further mods for adding this parrot.
    thanks again
  8. #6
    Jan 2012
    Post Thanks / Like
    Yes you probably will... I had a Parrot MK9200i fitted to my A3 and without the additional lead (a matchmute from Autoleads - around £60) you will only get the parrot through the front two speakers and it wont mute the bose speakers and sub in the rear of the car...
    Fine at first i thought... but after a while it really annoyed me! I bought the matchmute connection loom and it worked a treat. Bit of a job to install but worth it... my A3 has now gone unfortunately, so i have this loom as spare if ur interested?? ;-)
  9. #7
    Nov 2007
    HULL
    54
    Post Thanks / Like
    thanks for the reply, sorry only just checked it. i have now sent the autoleads one back due to whine and noise i bought a lead from nemesis audio (reccomended by parrot) for 70quid! wish i had seen your post earlier
  1. Symphony II & parrot.....
    By bendhamrait in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2012, 22:09
  2. Parrot CK3000 Evo mic & controller
    By JimLoskot in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th June 2010, 19:52
  3. Anyone fitted a Parrot to a Symphony II with Bose?
    By Alex2.0T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2008, 21:09
  4. Installing Parrot 3100 to Symphony II plus BOSE
    By Skittler in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2007, 12:09
  5. Installing Parrot 3100 to Symphony II plus BOSE
    By Skittler in forum In-Car Entertainment
    Last Post: 18th March 2007, 17:25
