Hi,
Ive searched the forum and still need help!!
My passenger side front door speaker works but has really low volume compared to the drivers side.
(Low as in you have to put our ear to the speaker to hear it)
Ive removed the speaker and swapped it with the drivers door speaker and its still the same on the passenger side.
So i think the speaker is fine.
Ive had a quick look and the wiring and theres no cuts or damaged to them that i can see.
Ive looked at the amp and the connection seems ok (not dirty/rusted as ive seen in other posts)
Ive had the problem since owning the car but its the first chance ive had to look into it.
I have the double din Symphony head unit (6 disk and tape)
its full Bose.
My car is a 2005 3 door A3.
Where should i look next?
ive been advised to find the drivers door and passenger door outputs and switch them over from the amp, to determine if i need a new amp. Is this the only way to check?
Does anyone know what wires i need to cut and swap?
ive got fairly basic knowledge/skills so be easy with me..
Thanks in advance
Tej
LinkBack URL
About LinkBacks
