Badger5JBS
Results 1 to 8 of 8
    Apr 2011
    Post Thanks / Like
    12V Switched Supply Query - AndyMac?
    Andy, the car's an A4 Cabriolet B6, 2004 reg. (non-Bose).
    A few years back you described the installation of a relay to provide the switched 12v supply for an aftermarket HU. I really like the solution & made up the relay on a piece of veraboard in a 'project box' ready to wire in. I then went looking in the car for what you described as the 'very tiny red wire' running in the plastic trunking to the left of the steering column. Undid the trunking & amongst the looms found one thick red(disregarded) & one medium red (about 2mm dia. including insulation). Is the medium red, the one you refer to? It's not really tiny - not as fine as the grey & blue running alongside which are <1mm.
    In case Andy doesn't see this, can anyone else who has done Andy's mod. successfully advise. I don't want to cut the wrong wire.
    Thanks for any help, B
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Don't cut any wires yet, use a 12v testing screwdriver and stanley knife blade or sharp pin and test the wire goes live with the ignition and stays live until you pull the keys out. In the hard top B6 it was definately the skinniest wire in the loom, could be different on the cabrio.
    Alex Turner
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    I believe there is no ignition switched 12v supply in the cabriolet (well not that I could find) its all controlled from the canbus.
    Get yourself one of these gizmos and it will give you all the outputs you need for an aftermarket hu.
    AUDI A3 A4 TT CAN-BUS ADAPTOR INTERFACE CAN-01 | eBay
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    It's all CANBUS in the non cabrio which is why you have t wire in a relay from the wiring off the ignition.
    CANBUS emulators don't actually provide a proper accessory feed, they give you ignition on only (doesn't stay live when you turn the ignition off), which you can easily pick up from the fusebox.
    Alex Turner
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    it stayed live until you took the key out, same as with the original stereo.
    Its go to be easier than wiring a relay across the ignition switch. plus gives you outputs for dimming etc. if the stereo illumination dims
    Apr 2011
    Post Thanks / Like
    Thing I didn't like was its £55! Whereas relay out of Maplin & a few other bits were about a tenner. I didn't want to spend more at this stage as its only an old Woodstock DAB 52 radio I had in the garage from another car & I might not like it in the dash & may replace it later. Fixed stereo illumination is about right with my dash setting anyway.
    BTW Andy, it was the right wire & is now working correctly (stays on after engine shut down until key removed & comes on immediately key inserted again).
    Apr 2011
    Post Thanks / Like
    correction: comes on again after key inserted & then turned to first detent
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Glad you got it sorted
    Alex Turner
  1. Which pin is "Switched +12V ACC" on rns-e quadlock?
    By Dannykn9 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2011, 14:09
  2. Switched 12V Fault!
    By gavin89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2011, 21:19
  3. Very basic guide to get a 12v switched supply please
    By lewie in forum In-Car Entertainment
    Last Post: 29th March 2011, 14:32
  4. Can I tap CD changer outlet for switched radio power supply?
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th September 2006, 19:07
  5. 12V supply into arm rest
    By AndyCollins in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2004, 12:30
