W8 PerformanceBadger5
Results 1 to 1 of 1
    Aug 2009
    15
    Post Thanks / Like
    New utility to load up your SD Cards from your iTunes library
    I've created a new utility called RoadMusic to help transfer iTunes playlists to an SD Card which work in the RNS-E head unit. I know there are others out there, but they didn't do exactly what I wanted, so I created my own.
    It takes into account the many limitations of the RNS-E, such as the file/folder size limits, unfriendly file names, playlist size limits etc. If you have a number of SD Cards, then it will help you split your library across them.
    So hopefully it'll take some of the guesswork out of loading up your tunes. I've also made it fairly user-friendly.
    The app will currently only work on a Windows PC with iTunes installed. I have version 10.5 and I've only tested it with this version. You will also need to have the .NET Framework 3.5 installed.
    IMPORTANT: The RNS-E only plays MP3 files. So this app will ONLY deal with MP3 files and the app will not convert any other type of file to MP3.
    This is V1.0 so I don't expect it to be flawless, but it works for me, so if you have any feedback then let me know on this thread. To diagnose any issues I might ask you to send me your "iTunes Music Library.xml" files and any problem MP3s.
    RoadMusicSetup.msi
  1. Off Road/Utility Styled A4 B5 Avant?
    By sigibbons in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th January 2010, 19:41
  2. ITunes playlists to SD cards
    By Keef in forum In-Car Entertainment
    Last Post: 25th June 2008, 13:28
  3. Audi A4 B5 DIY Library
    By Olly_K in forum General Technical / How To
    Last Post: 4th June 2008, 13:35
  4. Audi A8 DIY Library Completed at AudiDIY.com
    By Audidiy in forum A8/S8 forum
    Last Post: 18th March 2007, 01:55
  5. B6 S4 DIY Library now at AudiDIY.com
    By Audidiy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2007, 06:55
