Sky InsuranceBackdraft Motorsport
Results 1 to 16 of 16
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    Bluetooth for RNS-E
    Hi guys, can anyone tell me if a bluetooth module from an A3 would work in an A4?
    I would have thought it would be the same. I only ask because this one has the prefix 8P0 whereas all the ones I have been looking at start 8P1
  2. Thanks dan786 thanked for this post
  3. # ADS
  4. #2
    s8craig's Avatar
    Jul 2005
    Manchester
    1,101
    Post Thanks / Like
    Yes it would, the 8P0 module you have been looking at in the classifieds will work in the A3 8P/TT 8J/A4 B6&B7/R8 /A6 C5 models
    8P1 are the latest modules
    My Retrofit Website
    http://www.tclsatnav.com
  5. Thanks Paul100 thanked for this post
  6. #3
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    Ok got the unit, and pulled my dash apart to fit and have another question now....
    I already have a microphone fitted in the courtesy light unit..
    Anyone have a clue where the other end of this would be hidden? or where Audi usually fit the bluetooth modules? Have had a hunt around but cant find it, or a spurious spare plug (the other end of the mic cable) anywhere (was getting dark though...)
  7. #4
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    Ok fitted it and worked fine, then stopped working with the message 'phone not connected or device not working'. So took it all apart checked connections etc, and it started working ok. Now put it all back together and not working again................... ARGH!!!
    vcds lite cannot connect to 77 telephone..
    Anyone have any ideas??
  8. #5
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Have you coded the Radio to accept Telephone?
    Where did you find the end of the microphone cable?
    Audi A3 2.0TFSI S Line SE DSG
    Cruise Control | Ambient Lights | LED Lighting | Full Leather | RNS-E MK2
    OEM Bluetooth | AUX | CH/LH Lights | MFSW | S3 Pedals | BFT Remap
    JMB Retrofits - North East Retrofit Company
  9. Thanks Paul100 thanked for this post
  10. #6
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    Quote Originally Posted by jb0o View Post
    I did re-code the radio (well navigation tab in vcds) should there be another part I should code? Seems strange as it was working??
    I didnt find the other end of the mic cable in the end after an hour or so of searching I decided it was quicker to just install the new one a run the cable around (only took 20mins..)
  11. #7
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    Any ideas????
    Also I have noticed that my car is beeping at me (3 short beeps) whenever a door (or the boot) is opened. Thats only started since the bluetotth install.......
  12. #8
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    You also need to code in the CAN Gateway #19 I believe.
  13. #9
    s8craig's Avatar
    Jul 2005
    Manchester
    1,101
    Post Thanks / Like
    I'm confused as to which mic you used as you said you have one in place. Have you by any chance used one of the alarm sensors which may be why your car bleeps now.
    My Retrofit Website
  14. #10
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    Oh that's a thought, I assumed it was a Mic as it was installed in the 'mic position'. Is the microwave alarm sensor normally in the courtesy light unit? As I disconnected this and put the new Mic in its place....
  15. #11
    Cruiser89's Avatar
    Bournemouth, Dorset
    602
    Post Thanks / Like
    Yes it is.
    Also if you have BOSE then there will be a mic there that listens to the sound output in your car.
    If your car did not come with Bluetooth installed it would not of had a mic fitted.
  16. Thanks Paul100 thanked for this post
  17. #12
    s8craig's Avatar
    Jul 2005
    Manchester
    1,101
    Post Thanks / Like
    What type of A4 do you have? The standard A4 mic is oblong and the cab mics from 2007 are round.
    I have a feeling you have been supplied a round mic and have removed the alarm mic to install it.
    hence the beeping
    My Retrofit Website
  18. #13
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    It's an '04 s4 cab. And yes with bose.
    It was oblong, in fact the sticker had the same part number ad the bit I put in, which is why I assumed it was a Mic......
    Better put it back in then..... Doh!
  19. #14
    s8craig's Avatar
    Jul 2005
    Manchester
    1,101
    Post Thanks / Like
    Ok, that clears things up, the 04 cabby has two oblong mics, the existing mic is for bose and should be relocated to the other end of the lighting dome. So BOSE Mic on the left, TEL mic on the right.
    Still doesn't answer why your car is beeping unless you dislodged one of the alarm sensors in the dome.
    My Retrofit Website
  20. Thanks Paul100 thanked for this post
  21. #15
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    ok guys all working now.
    Many thanks for your help.
    I re-installed the existing mic (as you said Craig keeping the bt one closest to drivers side) and all is working fine. The beeping has stopped, and the bluetooth now works............. hurrah!!
  22. #16
    Sep 2011
    West Sussex, UK
    112
    Post Thanks / Like
    Hmmm it would seem I spoke too soon.....
    This bluetooth seems to have a mind of its own? it worked when I reinstalled the 2nd mic, and once since. But now deosn't seem to be in the mood?
    In fact my phone cant even discover it now let alone connect????
    It doesnt help that I only have vcds lite so can't communicate with the telephone control module (77) to see whats going on in there...
    Any ideas?
  1. Bluetooth on RNS-E
    By A4_MO in forum Satellite Navigation
    Last Post: 29th November 2011, 15:29
  2. RNS-E Bluetooth
    By aps55 in forum In-Car Entertainment
    Last Post: 14th August 2011, 13:15
  3. RNS-E And bluetooth
    By matt123890 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2010, 21:40
  4. RNS-E Bluetooth
    By itsmeagain in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd May 2010, 13:25
  5. rns-e bluetooth
    By rickparmar in forum In-Car Entertainment
    Last Post: 9th March 2009, 21:30
