AMD TechnikUnicorn
    Nov 2011
    21
    Post Thanks / Like
    S3 8P aftermarket amp install - Bose harness connector availability??
    Does anyone know if a harness adapter is available to plug into the cars harness at the Bose amp in the boot, so that i can take the pre-outs to an aftermarket amp? Id prefer to use a plug'n'play option rather than cut the cars harness.
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    No there isn't, the plug on the Bose amp is enormous. You can use piggybacks without damaging the stock wiring, details here:
    http://freepdfhosting.com/6b28e2fdcb.pdf
    Alex Turner
    Nov 2011
    21
    Post Thanks / Like
    Thanks Andy, can you just leave the Bose amp unplugged after attaching the piggybacks?
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    If you are completely bypassing the Bose amp then you'd be better using small blade terminals plugged into the Bose connector. I do an RCA adapter for just this purpose, far easier to install and a guaranteed connection. Piggybacks are pretty hit or miss and the wiring in the Bose lead is very tight. Jus take an RCA cable chop it in half, strip back the insulation so you then have the 4 signal wires, and 2 screens then solder these to small blade terminals and plug these into the corresponding slots on the Bose plug. Then wrap it in electrical tape. It's fine to leave the amp unplugged.
    Alex Turner
  6. Thanks Reevesy thanked for this post
  1. Wiring harness required for aftermarket HU on S3 bose?
    By sportstractor in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2010, 22:19
  2. Availability of S4 Bumpers & Skirts?
    By sigibbons in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th January 2010, 20:36
  3. A3 Non Bose Sub & Amp Install - Confused
    By Aaron TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th December 2009, 15:01
  4. BOSE Connector help!!!
    By KillerUK0 in forum In-Car Entertainment
    Last Post: 26th May 2009, 00:18
  5. bose rns e harness to non Bose system
    By vinceemmery in forum In-Car Entertainment
    Last Post: 6th December 2007, 07:23
