Hi Guys,
8E B6 A4 Concert 2.
Some of you have been helping out with my parasitic drain issue in the B6 forum(thanks), flagged up some CCM codes and some door lock codes, I found some sheared wires in the door, last place I checked! (AAARRGGHHHH!!), fixed them so no more weird codes when scanning modules, however, the hazard still stays on till I reset a radio code I have....
00858 - Connection; Radio ZF Output to Antenna Amplifier - Short to Ground
36-00 - Open Circuit
When I clear this code it comes back immediately but what I did notice is that even though it comes back, I pull vag cable, lock car and hazard goes off! Result! but the hazard comes back on by my next drive, I can only think its shorting with the cold mornings? Im guessing this means this is definitely causing my drain issue?
What should I do now? Unplug the antenna amp? Anybody else with this issue shed some light?
LinkBack URL
About LinkBacks
Audi S3 8P3 2.0TFSi
