W8 PerformanceDTUK
Thread: Subwoofer Help
    Nov 2011
    Central Scotland
    160
    Post Thanks / Like
    Subwoofer Help
    Recently got a audi s3 2001 model and cd player was not working with it so got £100 knocked of price. Just had it repaired was power source part and now working fine.
    Noticed that subwoofer is cutting in and out when i turn the volume up on the headunit and it seems to do it worse when cold. If i go on a longer drive it does it less once warm,
    Can anyone help with what might be causing this ???
    Looking at a andymac set up but can't afford right now.
    thanks
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Is it the Bose setup you have?
    Alex Turner
    Nov 2011
    Central Scotland
    160
    Post Thanks / Like
    yes concert headunit and bose system
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Bose amps seem to be prone to dry solder joints on the PCB as they age, which is why it is bad on a cold morning and improves as everything warms up. If you remove the sub (not a small feat, instructions below) remove the front of the sub, the tiny Bose amp is screwed to the back of one of the 4" subs. Prise off the top and unscrew the PCB, and using a soldering iron and solder sucker reheat all the main joints and resolder them. This has worked numerous times for me and others, otherwise you need to replace the amp. I have a spare one kicking about which you are welcome to have for a tenner. PM me if interested.
    When replacing the front of the sub be careful not to overtighten the middle Torx screw i.e. don't use a cordless screwdriver as the plastic it screws into is prone to snapping and then the whole enclosure leaks and farts like a *******,
    http://freepdfhosting.com/37841f9301.pdf
    Alex Turner
  6. Thanks djx11b thanked for this post
    Likes djx11b liked this post
  7. #5
    Nov 2011
    Central Scotland
    160
    Post Thanks / Like
    thanks for your help and amp offer have sent you a pm about it
  1. Who's got a subwoofer?
    By The Maestro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2010, 11:09
  2. Anyone Got A Subwoofer?
    Last Post: 2nd April 2010, 17:30
  3. Bose Subwoofer
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2010, 15:18
  4. Installing a subwoofer
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2009, 10:20
  5. Subwoofer
    By cyclopspig in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2007, 20:25
