Backdraft MotorsportDPM
Results 1 to 13 of 13
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,014
    Post Thanks / Like
    ICE Upgrade in 8L S3
    Well as some of you may have read, I recently installed a new headunit in the S3, I went for the Parrot Asteroid which is a pretty nifty piece of kit and does a lot of stuff.
    My review of it is here for those that are interested: Parrot Asteroid
    I re-wired the speakers to the headunit and by-passing the amplifier for the rear speakers leaving it to power just the standard subwoofer.
    I've since decided that the standard speakers fitted in the car are pretty poor when it comes to sound quality, at least in my opnion they are. Not wanting to live with it anymore i've decided to embark on an upgrade.
    Having said this, i'm not about to blow serious cash, I want to keep it afforable but half decent - the whole idea of me buying the S3 in the first place.
    Fronts
    Nothing too fancy and something that will fit behind the door cards as I don't want anything to be visible, so no clever creations with mdf and fibreglass here i'm afraid.
    I've been very impressed with the Focal CAs in my Mazda and so i've popped for a pair of Focal 130A1 component speakers. I plan on using some adaptors of course (AndyMac specials if I can find out where to get them..). These will fit depth wise, and will be helped along with sound deadening in the right places.
    Rears
    For the rears again i'll be going with Focal, but this time i'll use coaxials for the job and will be using Focal 165CA1. Again fitted with the relevant adpators and plenty of sound deadening.
    Amplifier
    I'm a fan of driving the main speakers from an amp and I though if i'm pulling the car apart to fit the speakers then I may as well just do the lot at the same time.
    Again i'm tryin to keep things small and compact and out of sight. I believe there is plenty of space for a 4 channel amp behind the rear speaker panels, probably the drivers side (in case of future AMSS upgrade needing the passenger side).
    I've decided on another JL Audio XD400/4. If you've not heard these little Class D amps in action then you should. Their size belies their true ability and the sound reproduction from them is astonishing really.
    Read up here for those interested: JL Audio XD 400/4 Amplifier Review
    Subwoofer
    I'll probably leave this for the next stage and see how the speakers bed in over the next couple of months, and then decide on sub requirements.
    I've always been impressed by AndyMac's solution when i've heard it in other's cars and from the reviews of it on here. Again it also ticks the "hidden from view" box which is a big plus point for me.
    So my shopping list for now is:
    1x - Focal 130A1 Components
    1x - Focal 165CA1 Coax
    1x - JL Audio XD400/4
    Speaker cable & RCAs
    4g power cable and earth, fuses etc
    Rhino sound deadening material
    4x AndyMac MDF speaker adaptors
    The speakers are ordered, so they should be with me in the next couple of days. I want to make sure I know exactly how to mount the amp, and where to channel the power to the battery etc before stripping the car down.
    I'll update with pictures soon!!
    alijames's Avatar
    Feb 2008
    Oxford
    1,016
    Post Thanks / Like
    The AndyMac Sub: It rocks! Simple.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    Four Doors for more Whores ;)
    Feb 2011
    Leeds
    89
    Post Thanks / Like
    Front Speaker rings
    Audi A3/S3 8L MDF front speaker adapters 13cm 5.25" component | eBay
    Rear Speaker rings
    Audi A3/S3 8L MDF rear speaker adapters 165mm coaxials | eBayhen i installed my amps in my car i removed the glovebox and fed the power cable through a grommet in the top right hand corner of the engine bay, which fed the power cable straight through into the car behind the glovebox.
    For my earthing point I undid the rear trim panel in the boot and used one of the bolts near to the boot catch for the earthing point
    Feel free to drop me a PM if you want anymore ideas/help
  5. Thanks beanoir thanked for this post
  6. #4
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,014
    Post Thanks / Like
    Thanks for the link mate. I've ordered a couple of pairs of the adaptors from AndyMac, so hopefully I'll have them for the weekend.
  7. #5
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,014
    Post Thanks / Like
    Speakers and adapters haven't turned up yet so could look like I wont be doing that this weekend unless they arrive in tomorrow's post...here's hoping.
    In the mean time I've focussed my attention to the music storage. The Parrot Asteroid has the capacity to stick as big an SD card in as you can get hold of. I've got a 32GB in there at the moment but in order to get all of my music library on it I have to convert it from Lossless audio format down to a 19kb mp3. The result is not as good as I would like and the difference is certainly audible. So given I can't get a 125gb SD card to fit all my music on and the fact portable hard drives are not too expensive these days I decided to get myself a 500GB unit that will comfortable fit my entire music library on and also plenty of room for the future.
    I opted for a Western Digital Passport which looks pretty boring in black, but then it'll blend in with the interior nicely and fits in the cubby hole beneath the headlight switch. Its also got pretty quick data rates and the like so it should function pretty well, and certailny better than the old 2G iPod I was used to.
    The result is pretty good, I have all the music I own there at the push of a button in my car....sweet ride!
  8. #6
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Nick, I sent the adapters yesterday 1st class recorded so you should hopefully have had them this morning.
    Alex Turner
  9. Thanks beanoir thanked for this post
  10. #7
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,014
    Post Thanks / Like
    Hi Andy, I did indeed find them sitting on the porch when I got home this afternoon, so thanks for that I'll leave feedback of course.
    They look quite good I have to say, very well made and thought out. Thumbs up sir.
    My speakers haven't turned up yet, but looking forward to fitting them next weekend hopefully.
  11. #8
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    I use those Focals in the front of my A4 and they are a superb speaker, as long as you don't want to drive them hard. Once the volume gets up they seem to lose their accuracy and sound crashy.
    Life begins at 140mph
    www.passionford.com
  12. #9
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,014
    Post Thanks / Like
    Quote Originally Posted by Oranoco View Post
    Are your's amplified?
  13. #10
    Jan 2011
    54
    Post Thanks / Like
    Quote Originally Posted by beanoir View Post
    Yeah from what i recall all oranocos speakers are amped he wouldnt have it anyother way
  14. #11
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,014
    Post Thanks / Like
    Quote Originally Posted by tsporta4 View Post
    Thats interesting, i've not had these problems. I actually have the same set up in another car Focals/JL Audio XD and it really does drive well at high volume. It could just be down to other factors I guess.
    Still, either way it's going to sound a dam sight better than what Audi managed!
  15. #12
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,308
    Post Thanks / Like
    Yes all amped. I used an Alpine 9812RB with on board amplifier switched off to give the preouts the best possible output. At present they are being driven from an old Kenwood PS301T. I don't think the position and mounting method for speakers in the B5 A4 does the audio set up any favours at all.
    www.passionford.com
  16. #13
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,014
    Post Thanks / Like
    It could be a number of things to be honest, the Focal Access are generally easy to drive and not normally too fussy, but position is a big issue and not one we can do much about unless we want to start making pods and all that - which if you're like me you probaby don't.
    I'll see how it sounds when i've fitted them, the next step could always be to stick a Bit Ten in but thats not what i'd been planning and adds to the costs and bulk, but they do work wonders!
  1. S3 (8L) recommended upgrade for ICE
    By stevewushu in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2010, 19:22
  2. S3 ICE Upgrade
    By ChriS3 in forum In-Car Entertainment
    Last Post: 5th April 2007, 08:49
  3. AUDI A3 ICE UPGRADE HELP
    By Bran in forum In-Car Entertainment
    Last Post: 18th November 2006, 19:34
  4. Standard Ice upgrade
    By garratt83 in forum In-Car Entertainment
    Last Post: 20th October 2006, 14:21
  5. 1999 A3 ICE upgrade
    By Digga in forum In-Car Entertainment
    Last Post: 9th March 2006, 19:54
