Volks AutosMonster Motorsport
Results 1 to 7 of 7
    Jan 2011
    48
    Where is the standard amp in the boot ?
    Hi I have fitted a aftermarket hu and the rear speakers are quite as a mouse! Have the correct cables all in half amplified . So the option now is to either rewire the speakers direct or replace the amp and run the speakers from that. So where in the boot do I find the amp on a 55plated a4 1.8t cabriolet . Any help would be appreciated ! A photo would be good as I can't fun one anywhere! Thanks mj.
    Jun 2003
    World of my own
    9,813
    It should be behind the boot trim on the drivers side wheelarch, might be different on a cabrio though, but that's where it is on all A4's I've seen.
    Alex Turner
    Jan 2011
    48
    Thanks Andy i'll try and check tomorrow if i get a chance might take a pic and post for others. Am i right in thinking as the dvd head unit ive had installed will not work the rear amp to give any decent sound? it plays through the rear but the front is twice as loud? no amp i'm guessing? also what the answer to the radio signal being shocking ? using a amp transmitter on it , Once againthanks for your knowledge on this item !
    mj
    Jun 2003
    World of my own
    9,813
    It's twice as loud at the front because the fronts are driven off the HU. The new HU will have at least twice the power of the stock Audi 2 x 20w HU but you still have only 2 x 20w from the rear amp. Drive the rears off the HU, twice the power and better quality. You just have to run speaker cable from the HU to the boot and then you can pick up the rear speakers from the connector from the Audi amp. Should be the same as the B6 amp:
    This diag may have the +ve & -ve's reversed as I used it recently and had to swap them over as the rears were cancelling the bass from the fronts.
    The aerial needs an antenna amp adapter on it in order to power the aerial amp. Check it has one and that the blue flying lead is connected to a switched 12v feed i.e. power antenna or remote on on the new HU.
    AAN2122 Active Aerial adaptor
    Alex Turner
    Jan 2011
    48
    Thanks I used a amp aerial off the original cable not the small yellow one they said to use picked up a stereo signal straight away and tmc for gps . Just need to rewire the rear speakers which Im hoping isn't to hard to do!
    Jan 2011
    48
    Hi how do I get to replace the rear speakers? I took the rear seat out then I couldn't see where to go Next? I'mTrying to replace them and also the sub which I have no idea where it is or how to get to it?? I thought there were bound to be a website showing how to but searched the web and nothing?Thanks in advance if you can help!Mj
    Jun 2003
    World of my own
    9,813
    Alex Turner
  1. Where in London do they do custom boot fabrication sub box & amp ???
    By Digzz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th October 2011, 22:23
  2. Replies: 0
    Last Post: 26th October 2011, 18:58
  3. Tax disc missing & car boot & door open
    By nanafagis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st July 2011, 16:53
  4. Replies: 0
    Last Post: 8th September 2010, 11:29
  5. Replies: 1
    Last Post: 17th January 2008, 17:27
