AMD TechnikJuicy
Results 1 to 10 of 10
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Where to put sound deadening
    I just recieved my bulk pack of 41 sheets of silent coat which weighs a ton!
    I paid £80 for it + I bought a roller tool to really get it stuck to the body work.
    On my 8P 3dr where should i be laying this stuff down..
    Door wise I assume only inner skin as I cannot get to the outer?
    Rear panels, whole boot...
    Anywhere else?
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    anyone?
    18,280
    Post Thanks / Like
    In your ears
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,014
    Post Thanks / Like
    you can stick it everywhere, to be honest it depends on how much weight you want to add to your car, because like you rightly point out, it weighs a ton.
    The best bet is a 6-10 inch square behind your speakers double layer is better too, so ideally stuck to the door skins. And then any metal that is open to the back of a speaker really if you imagine the door as the speaker cabinet. The more you use the better sound you'll get, but the more weight you'll add, so it's horses for courses as they say.
    I also like to make a gasket form the stuff and mount it between the speaker and the door or wherever its screwed to.
    If you have a sub in the boot, then do the inside of the boot door and sides of the boot again, against the inside of the outer panel.
    I assume you're not doing this to minimise road noise, which is another use for the stuff but involves sticking in different places, like the floorpan!
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    Wheel arches helps reduce road drone noise too. Spare wheel wells tend to be quite thin and resonant. Then door skins as Nick says.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Thanks all. I shall attack the suggested areas.
    regards to weight, ive had the box in the boot for a week and have not noticed any MPG reduction/handling changes due to weight so will make sure I use the lot - even if i have to double up!
    Jun 2011
    17
    Post Thanks / Like
    hi i have mine underneath the rear passenger seats, rear quarter pannels, underneath the boot carpet and spreading across into the spare tyre mould space, and in the tailgate to. it seems to do the trick, however it doesnt always stop all vibrations from reaching the car metal, all depends on how loud the system is.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Ive started in the boot and trying to cover as much metal as I can but had to stop as it was killing my hand pressing it down nice and hard into the gaps and ive managed to cut my hands up asweel on the sharp edges!
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    You really are wasting your time covering every inch. Sound deadening obeys the laws of diminishing returns, so covering the large areas will give the best results. All the small areas will not benefit at all.
    Alex Turner
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Id say im covering 80%..
  1. Under Bonnet Sound Deadening
    By GrayT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd June 2011, 09:52
  2. A3 8L door sound deadening HOW TO?
    By moochinazz in forum In-Car Entertainment
    Last Post: 16th November 2009, 23:00
  3. Sound deadening doors
    By fenian672000 in forum In-Car Entertainment
    Last Post: 4th February 2007, 00:05
  4. A3 boot, sound deadening suggestions...
    By Pete69zx in forum In-Car Entertainment
    Last Post: 29th November 2006, 16:01
  5. Sound deadening
    By jdp1962 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2005, 17:46
