Forge MotorsportAMD Technik
    Sep 2009
    West Mids
    48
    Post Thanks / Like
    A3 sportback TDi subwoofer
    The rear subwoofer speaker unit in my 2006 A3 sportback 2.0 tdi has obviously gone faulty, it sounded like a swarm of bees, making a buzzing noise which was very audible at low volume levels.
    I took the car to bits and removed it from the subwoofer assembly as it was bloomin' annoying. I couldn't see anything stuck in the speaker which could be causing the buzzing
    Could anyone recommend a direct replacement for the actual speaker unit itself as i dont really want to replace the whole subwoofer unit, I've seen them offered on a popular selling site for between £50 upwards.
    I may even not bother replacing it as I cant really hear a great deal of difference in the music quality.
    Thanks for any advice or comments
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    There aren't any direct replacements and if there were you're unlikely to get one for less than £50. There are 2 types of subwoofer for your car, Bose & non Bose. They are very different so you need to ensure you get the correct one. The Bose one just houses the speaker and the non Bose houses a different speaker and the amp that drives it and the rear speakers. The buzzing is probably caused by the speaker being blown, if you gently push on the speaker cone it should move smoothly in and out. If it crunches at all then then voice coil is broken. Just replace the whole unit or add a proper sub.
    Alex Turner
  1. New A3 sport 2.0 TDI Sportback (170 HP)
    By Alexwhit in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2011, 11:40
  2. what the fuel ! 2.0 tdi sportback
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2011, 09:31
  3. A3 TDI 2005 Sportback
    By keithrg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2010, 20:08
  4. a3 sportback or hatchback TDI
    Last Post: 5th December 2008, 17:47
