Adrian S FluxSky Insurance
Results 1 to 16 of 16
    Naj
    Naj's Avatar
    May 2011
    75
    Post Thanks / Like
    Replacing Concert with aftermarket unit -n00b!
    I'm a n00b when it comes to ICE. I want to replace my Concert unit with a Pioneer DEH-4000UB. I have a PC9 - 404 wiring harness. I've connected it all up but am getting no power to the unit. Any help woulde be appreciated!
    04 Audi A3 2.0 TDI Sport
    kev1000's Avatar
    Jun 2011
    County Cork, Ireland
    147
    Post Thanks / Like
    Don't hold me to this but I think the red and yellow wires need to be switched around.
    Please wait for someone else to confirm this as i'm after forgetting since I done my one!!!!
    Rastamouse's Avatar
    Welsh Audi Nut
    Aug 2011
    154
    Post Thanks / Like
    I had this problem when i swapped mine to a kenwood dnx7220 multimedia unit, i had to get a permanent live put in by a local audio company and that sorted it out.
    Jul 2011
    172
    Post Thanks / Like
    There are 2 ways to do this, you can either tap the red wire into the yellow wire, this will give you the permanent live needed to power up your head unit.
    The downside to this is, you have to manually switch off your headunit everytime you leave your car.
    The other option is to take a switched live feed from your fusebox to your headunit, this will switch your headunit off everytime your key is removed from the ignition.
    If you do a search, there are several discussions regarding this.
    Hope this helps.
  6. Thanks Naj thanked for this post
  7. #5
    Naj
    Naj's Avatar
    May 2011
    75
    Post Thanks / Like
    Quote Originally Posted by slappy View Post
    Hope this helps.
    Aahh I see it does say on the head unit install guide it maybe necessary to switch the red and yellow I don't mind having to switch it off manually as I always take the face off when leaving the car. But will the unit retain its settings with this method?
  8. #6
    Jul 2011
    172
    Post Thanks / Like
    Yes it will if both wires are connected up, the head unit has a permanent live feed going to it to retain any memory settings.
  9. #7
    Naj
    Naj's Avatar
    May 2011
    75
    Post Thanks / Like
    So I've got power going to the unit now. Sounds way better. Not getting any sound from the rear speakers? If I send all the sound to the rear, I jut get faint bassy sound.
  10. #8
    Jul 2011
    172
    Post Thanks / Like
    Have you connected the red plug? This feeds your rear speakers, the 2 phono plugs goes into the back of your head unit and the blue one if I remember correctly is the earth.
  11. #9
    Naj
    Naj's Avatar
    May 2011
    75
    Post Thanks / Like
    Yeah, the red connecter is plugged in. The blue and white cable connects to the corresponding coloured cable on the HU labelled 'remote'. This appers to give the rear amp/speakers power to produce the little noise I hear. The phono plugs are connected, though the black is connected to a white port on he HU (?). I've since learnt that the rear amp is only 2x20w and my HU built in amp would be much better. How difficult is it to wire the rear speakers directly to the HU?
    The blue cable on the aerial adapter is connected to nothing, is this important?
  12. #10
    Jul 2011
    172
    Post Thanks / Like
    Quote Originally Posted by Naj View Post
    You'll need to check your head unit documentation to see if this is correct, the black should be ground.
    That's true, the rear amps are crap, wiring direct to the headunit is relatively easy, the only time consuming part is removing any trim to pass your speaker cables through.
    It will sound much better than using the stock amp, while you're at it, why not change the rear speakers at the same time.
    It shouldn't take anymore than a couple of hours to do at most.
    That's normally a feed wire for the antenna adaptor, you'll need to wire this up as well if you intend on using the radio functions.
  13. #11
    Naj
    Naj's Avatar
    May 2011
    75
    Post Thanks / Like
    So thats just disconnecting the rear amp from the speakers and running 4 speaker cables from the head unit?
  14. #12
    Jul 2011
    172
    Post Thanks / Like
    Yes, that's correct.
    Just make sure that you get the +/- (positive and negative) connections for the speaker cables the right way round.
  15. #13
    Naj
    Naj's Avatar
    May 2011
    75
    Post Thanks / Like
    Do I have to take bits of the dash off? What path does the existing cabling run from the rear speakers to get inside the dash?
  16. #14
    Jul 2011
    172
    Post Thanks / Like
    I'm not sure where the original cables run from.
    When you install the speaker cables, run the left speaker cable along the passenger side of the car, run the right speaker cables along the drivers side of the car, get the cables under the steering wheel (cable tie the cables in).
    Take out the glovebox for the passenger side to make it easier for you.
  17. #15
    Naj
    Naj's Avatar
    May 2011
    75
    Post Thanks / Like
    Thanks, will have a bash at it. Thanks for your help!
  18. #16
    Jul 2011
    172
    Post Thanks / Like
    No probs, you're welcome.
  1. Replacing Concert Head Unit with aftermarket
    By Blue_Thunder in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th August 2011, 12:58
  2. S3 Concert Stereo Ipod Connection or aftermarket head unit
    By Fandango80 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2010, 22:37
  3. Replies: 4
    Last Post: 16th June 2010, 12:30
  4. Replacing standard head unit with an aftermarket one question
    By AR-CoolC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2009, 18:36
  5. Replacing a Concert III with aftermarket headunit - many issues?
    By Gunstar in forum In-Car Entertainment
    Last Post: 4th March 2009, 23:12
