Adrian S FluxDPM
Results 1 to 7 of 7
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Adding bass to the Concert system
    Hey guys
    I have an A3 8P 3dr with the Concert CD player.
    I have subs and amps of all sizes and will be building my own enclosure to suit.
    Do I have an Amp and Sub as standard in my car?
    And is it easy enough to use the stock stereo and wiring to add in my own amp and sub?
    What kit do I need to take from the standard wiring to create RCA and remote?
    Assume I will need to run a new power/earth as per normal?
    Any info appreciated.
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    All 8P's have a subwoofer unless you have the real entry level version with no rear speakers. Wiring up an additional amp depends if you have Bose or not. With non Bose the sub amp is inside the tupperware sub and also powers the rear speakers. The Bose system has a 6 channel amp, of which 2 channels run the sub, so you can disconnect it and not lose the cabin speakers.
    A lot of the info you need is here, including running power through the bulkhead:
    http://freepdfhosting.com/6b28e2fdcb.pdf
    Alex Turner
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Great cheers mate - Il have a good read of that.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Andy - How much can you do your RCA/Remote loom for mate?
    Im using my standard non Bose Concert HU and then want to build my own sub/amp enclosure.
    Ive read your instructions so know how/where to run power and earth cables.
    ...I just need the loom for the RCAs and remote.
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    The RCA loom is really for the Bose system. With non Bose you can run proper RCA's direct from HU as you are going to lose the rear speakers anyway. You need to check whether you have ISO or Quadlock on the back of the HU. Audi changed to Quadlock from approx 2005 on.
    If ISO then you need one of these:
    Hama Adapter Mini ISO 6-pin - 4 RCA (phono) Sockets - - fotemia.de
    Not sure if they do the same for Quadlock
    Alex Turner
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    270
    Post Thanks / Like
    Great cheers mate - home comes there is 2 sets of RCAs on that loom? Just in case you run 2 amps?
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Front & rear, so you can fade
    Alex Turner
  1. Adding an AUX to concert II+ headunit
    By Farmer_Harry in forum In-Car Entertainment
    Last Post: 15th September 2011, 23:48
  2. ADDING AUX IN TO MY CONCERT
    By matt_hilluk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2011, 00:28
  3. bose system adding ice .......
    By 10blazin in forum In-Car Entertainment
    Last Post: 14th February 2009, 17:45
  4. S3 8L Concert Adding sub + amp
    By HmanS3 in forum In-Car Entertainment
    Last Post: 14th March 2007, 11:02
  5. Adding a Sub to a non Bose Concert
    By mwarrey in forum In-Car Entertainment
    Last Post: 17th June 2006, 11:58
