KowalskiW8 Performance
Like Tree1Likes
  • 1 Post By S4_dan
Thread: Aftermarket unit into B5
    Oct 2003
    berkshire
    97
    Post Thanks / Like
    Ok, finally managed to remove the concert and got my new unit plugged in using PC6401 adapter. At first didnt get any rear speaker sound but quickly worked out i needed to connect the blue wire to my HU's amp switch output.
    However, the sound still sounds a bit odd from the rear, not quite as good as it did with the concert....i may be going mad but i think i remember reading a thread on here (that after half hour of trying to find i can't) where it says it will sound not so good due to the rear speakers running from the HU speaker outputs rather than rca's....is this correct? If so shall i just get a rca to speaker output adapter and splice that into the loom so the rears run from the HU rca's?
    Hope that makes sense
    Oct 2003
    berkshire
    97
    Post Thanks / Like
    Oh, its a 99 model non bose
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    No it won't sound right because the rears have their own amp, so by using the 401 adapter you are feeding the rear RCA's into the feeble 2 x 20w Nokia amp, whilst the fronts are getting a healthy 2 x 50w from the HU's internal amp. Far better to rewire the rears directly to the HU and bypass the poxy thing
    Alex Turner
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    998
    Post Thanks / Like
    As andy has said, either replace or bypass the amp...
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
    Oct 2003
    berkshire
    97
    Post Thanks / Like
    Gotcha.
    Is there not a rear sub as well?
    S4_dan's Avatar
    Jan 2006
    924
    Post Thanks / Like
    Yes, the amp and sub are in one black plastic unit hidden behind the trim in the boot. I have fitted and Aftermarket HU and fitted my own amp and sub. Rewired the back door speakers and the sound is 100 times better. Ditch the Audi amp/sub as it's pants with an aftermarket HU!
    Easy enough to do.
    MrGrumpy30 likes this.
    Audi A4 B5 2.8 V6 30V Decats (Gutted out cats) FREE to whoever wants to collect from York. PM me.
    Holiday lets in Wells next to the Sea: http://www.wellsholidaycottage.com/
