AWEsome GTIUnicorn
Thread: Bose booming
    Aug 2011
    Post Thanks / Like
    Question Bose booming
    I've just got a 2008 A3/8P Cabrio, with Symphony (III?) and Bose, but finding it massively boomy and muddy, even with the Bass set to almost zero.
    I'm used to decent bass (from a good home cinema setup, not Bose ;-) ) so I know it's not entirely right. No comments please about Bose not being as good as an aftermarket setup; that may be true, but I can't believe it's this bad for a premium option.
    It sounds as though the eq is all wrong, as though the head unit isn't aware of the Bose setup. To back this up, Gala is available in the setup menu, which it shouldn't be with Bose?
    Is there any way I can verify things are setup right, and fix the EQ (the commonly available 'hidden EQ' settings are only on Symphony I?)
    Phil
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    You need VCDS (VAGCOM) on the newer HU's in order to change the EQ
    Alex Turner
    Aug 2011
    Post Thanks / Like
    I pulled the head unit at the weekend, and found that the Bose wire wasn't connected, as that connector had been disconnected and replaced by a Dension Gateway (without a loop-through harness). I've now replaced that Dension with one with a loop-through harness and CAN support to get display on the DIS.
    The EQ still isn't great ("no highs, no lows, it must be Bose"), but an improvement on before.
    Phil
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    Bose is not great TBH, I was convinced there was something wrong, but then heard another. I'd previously been running full Alpine system with DVC 12" sealed box sub, X type components and V12 Amps.
    Wasnt going to tear the Audi apart like I did my Leon, so went for Bose compromise, but with unresonated performance exhaust you can barely hear anything other than tizz / Woolley boom unless you really crank it up.
Tags for this Thread
