AMD TechnikGNJ
    FactionOne's Avatar
    quattro'd Administrator
    May 2004
    Preston
    2,860
    Post Thanks / Like
    Blaupunkt DAB54 vs Bose - wiring queries (One for AndyMac?)
    Hi All,
    I've just had a go at dropping my Blaupunkt DAB54 into my 99 B5 Avant...
    I found a couple of (related) problems...
    I ordered fascia and aerial adapters (plus an Aux-In flylead), but didn't bother with a harness adapter as the DAB54 has mini-ISO blocks (as the Concert) for amplifier output.
    Anyway... My first problem was that I couldn't get the antenna adapter power pin into the ISO plug on the car's harness (seems to be a slightly different slider/lock design), and because there's one big block for the mini-ISO ones (which are actually three), I can't connect the Aux-In block and the block with amp connections at the same time.
    So at this point I'm thinking about a harness adapter, just so I can butcher it to my needs without damaging anything on the car...
    This idea gained weight when it became apparent that things might not be quite so pin-compatible anyway, as when I put the headlights on the DAB54 made a noise that sounded like it was getting 12V somewhere where it really didn't expect it.
    So... Can anyone recommend a harness to suit a 99 A4 with Bose (seems to be fully amplified, because without the top (mini-ISO) block connected, I heard nothing))... which I can bodge to suit the DAB54 better?...
    Cheers,
    Rob.
    PS> Also noticed some hiss on the amp, and it did pop when I rolled the volume down to 0 (but not when it comes back up) - just in case that's worth knowing.
    A4 B5 1.8TQS Avant - Lightened fuel tank, two fantastic wheel bearings - two more an unknown quantity, boot full of lenses.
    Jun 2003
    World of my own
    9,429
    Post Thanks / Like
    Best option is a PIE adapter, this allows you to split the solid mini ISO harness into the 3 seperate connectors so you'll get separate access to the cd changer port.
    PIE Precision Interface Electronics AA3-HAR EnfigCarStereo.com
    If you can't find one in the UK I've got one you can have for £15 delivered
    Alex Turner
