EM TuningChris Nott
    Apr 2010
    26
    Help! Removal keys stuck!
    The removal keys on right side are stuck, cant get them out either the soft or hard way..
    I think i put the keys on right side wrong side in the Navi!
    The keys on the left side is ok and the player comes gently out.
    What to do? Need a tip!
    Pic:
    pmk
    Oct 2010
    17
    They are clicked into place. Slide head unit out and push the small lugs down that hold the keys in place.
    Apr 2010
    26
    Thanks, but only the left side slides a little out.. The right side is stuck, and i cant get the keys out either..
    2,167
    Were did you get the keys, eBay?
    I think your only option is to push the keys in as far as you can, remove the glove box then try and push the unit out from the rear. After that chuck the keys in the bin!
