Adrian S FluxVAG Check
    Jun 2010
    Post Thanks / Like
    New A3 owner advice please....
    hi guys purchased an a3 sportback on a 56 with symphony 2 bose setup, controls on wheel & no phone cradle in the phone holder. i run a ipod classic atm whats the best way of connecting to it, ive heard of a denison unit, your thoughts? also if upgrade my htc phone to iphone & buy the 100 quid cradle can i play music through the stereo whilst having the phone on bluetooth and charging thus killing 3 birds with one stone?? how do i connect my current htc to the car, when i press the control on the steering wheel it just says connect to cradle??? i heard it should just detect it or am i confusing ami with mmi?? cheers in advance you v.clever lot
    Jun 2010
    Post Thanks / Like
    bump
    s8craig's Avatar
    Jul 2005
    Manchester
    1,101
    Post Thanks / Like
    Well the A3 with symphony has neither AMI or MMI.
    You can pair the HTC with the car for bluetooth, put the key in the ignition and turn to 2 position, use your phone to search for the car's bluetooth. You should find AudiUHVxxxx and the passcode is 1234
    As for a cradle, well the Audi systems do not supports music over bluetooth in the current A3.
    Get a Dension gateway 100 CAN fitted for your Ipod music and you can use that charge your Iphone and play music in the future.
    My Retrofit Website
    http://www.tclsatnav.com
    Jun 2010
    Post Thanks / Like
    cheers s8craig, getting to understand it all now, will try that tommorow, if i have the blank phone thingy in the car without the cradle will this still work via bluetooth or is the bluetooth only available if no cradle fiited if that makes sense, is it AND or OR, thanks
    s8craig's Avatar
    Jul 2005
    Manchester
    1,101
    Post Thanks / Like
    You will have bluetooth with or without a cradle.
    My Retrofit Website
