I have a Parrot CK3000 bluetooth set which I want to install into an A2. I tried previously using the ISO connectors supplied but this doesn't work with the Symphony II. I also did it manually and ignorantly used what I thought was the 12V switched. This seem to do something to the Symphony II which trapped the CD mecahnism and rendered it faulty. Luckily had it replaced under warranty. I found out that the 12V swicthed was in fact a CAN BUS line.
My question is how do get 12V swicthed and perm? Can I use the fuse box and connect to an empty fuse slot? How about ground? I was going to use a small spade connector and 'plug' it into an empty fuse slot. I have to find out which was switched 12V and which was perm 12V and just shove the spade plug in.
Any help appreciated. /ubbthreads/images/graemlins/laugh.gif
