AH FabricationsBadger5
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    bad earth? noise on MW/LW.
    I get interference when using MW/LW. I suspect it may be a bad earth somewhere in the circuit for the rear window aerial amp/booster. (I get alternator whine, plus noise from other electrical circuits)
    Does anyone know of common causes/locations of possible bad wiring or bad connectors for this circuit?
    the car is a 1994 100 C4 body.
    Thanks!
    Feb 2004
    Clearfield, PA
    892
    Re: bad earth? noise on MW/LW.
    you actually use MW/LW???
    wow ...
    Nov 2004
    London UK
    2,614
    [ QUOTE ]
    wow ...
    [/ QUOTE ]
    [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    audi5e's Avatar
    Jun 2004
    809
    Thanks AndyMac, I managed to source the problem about half an hour before reading your post... [img]/ubbthreads/images/graemlins/smile.gif[/img] (the aerial amp is behind the rear quarter window covers, the bolt holding the amp to the body was loose, this must also act as the earth since the problem seems solved now that the bolt is tight... [img]/ubbthreads/images/graemlins/smile.gif[/img] )
