AH FabricationsChris Nott
Results 1 to 17 of 17
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    shark fin aerial
    hi
    i have purchased a shark fin aerial for my A3.
    however it wont plug into the standard aerial
    does anyone no if you can buy a converter to connect the 2 aerials together ?
    thanks
    Jun 2003
    World of my own
    9,813
    Alex Turner
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    that's not the one
    Jun 2003
    World of my own
    9,813
    Well you could tell us what model A3 you have but I'll take a wild stab at an 8P in which case you need the fakra adapter:
    Connects2 CT27AA10 Aerial Adapter Fakra Female - Din Female CT27AA10 by Connects2 - Low Cost Car Audio secure online shop
    Alex Turner
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    hi
    that could be the one ?
    the model is a 2003 03 8L
    thanks
    Jun 2003
    World of my own
    9,813
    If it's an 8L then it will be ISO on the HU, not Fakra
    Alex Turner
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    ok cheers
    if i have time tomorrow i will get some pictures up of the 2 connections.
    it is strange how the shark fin is a universal fit but it dont fit audi :s
    26,774
    So is it an audi sharkfin from a later car or aftermarket?
    Pic from google would suffice.
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    its an after market aerial from ebay item here
    AUDI A3 A4 A5 A6 A8 R8 TT Q5 Q7 Shark Fin Aerial on eBay (end time 14-May-11 12:42:49 BST)
    Jun 2003
    World of my own
    9,813
    Yes that's a DIN connector on the aerial and it'll be ISO on the HU as long as it's the stock HU so the first adapter is the right one.
    Alex Turner
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    Quote Originally Posted by AndyMac View Post
    ok cheers andy
    i dont want to put the standard aerial back on as these look way better.
    so hope it works :D
    looks like im going to have to run a live wire as well with this shark fin though
    its wierd how they work
    26,774
    Make sure its switched or it could flatten your battery, found out the hard way years ago when testing 1 of these on my S3, lol, oops, sure it was identical to that aswell.
    IIRC the antenna base in roof lining had a pcb integrated which I assume is an amp, should be for the £170 they cost in etka, cant recall fully as was years back now when I played with my S3 antenna, but was fed by a fakra type end on it, so unless you cut it & fit new connector, then you may have to run a new stretch front to back with a switched supply, bare in mind if its switched then using radio would need ignition on for antenna to give best reception.
    I would leave stock wiring there to swap back when selling car.
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    so my shark fin is a DIN ?
    i have taken a picture of the standard aerial in my a3
    the one you suggested andy looks different
    Jun 2003
    World of my own
    9,813
    That looks like an ISO female (should really be male) that won't plug into anything, can you tilt it round and take a pic?
    You should have exactly the same connector on the HU, so you need an ISO male to ISO male (wierd), which I don't think exists
    Alex Turner
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    that picture above is a male connector
    the original standard factory aerial plugs into this ( female )
    what that connector in the picture is called who knows. ?
    the shark fin is an iso
    what goes into the back of the head unit is one of these
    http://www.motor-world.co.uk/clients...ails/PC528.jpg
    so i need iso to what ever that is i took a picture of.
    brains rattling lol
    Jun 2003
    World of my own
    9,813
    The OEM aerial is male ISO at the HU end (same as the picture above), the socket on the back of the HU is female ISO. The connector on the shark fin is male DIN, so you need female DIN to male ISO as originally stated. I assume you need it to run the full length of the car so one of these?
    Autoleads PC5-60 4.5m Universal Aerial Extension Din - Ice Dot Com Express - Ice Dot Com Express
    and then use the adapter above to convert it to ISO to plug into the HU
    Alex Turner
    Audi-Power's Avatar
    Apr 2011
    South Yorkshire
    82
    ok just cant find any thing that looks like this.
    ive looked and looked lol
