Volks AutosBadger5
Results 1 to 14 of 14
    Apr 2011
    63
    Replacing audi Symphony with BnS 5.0 to my A3
    Recently i upgraded my concept to Bns,i bought an adapter(AUDI Einbauset Adapter Navigation RNS-E A2 A3 A4 A6 A8 | eBay) and an original bns disk + antenna.
    The problem is the following:Although bns is playing perfect in the DIS i dont have radio information.
    I search the web and i think that my solution for the DIS problem would be a possible replacement of can bus gateway ??? or the adapter is wrong ?? Whats your opinion ,any help appreciated
    Rns adapter is different as i saw in the net with the one i bought.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Well looking at that picture from Ebay I can't make out any CAN bus wires in pins 7 & 12 of the RED connector, which is probably why you have no radio information.
    Does the BNS switch on and off with the ignition?
    Apr 2011
    63
    The Bns doesnt switch on with the ignition.I am going to buy the following adapter that includes can bus simulator ( RNS-E Adapter + Can Bus Interface AUDI Navigation Navi on eBay (end time 21-May-11 06:49:12 BST) ) . What do you think so?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I think you should just buy the correct adaptor set. The symphony II has can bus, so your just missing two wires from ping 7 & 12 of the red connector to pins 9 & 10 of the quadlock. You do not need a can bus simulator.
    This product allows you to specify the options you have and what you are fitting.....
    KUFATEC GmbH & Co. KG - Audi Bundle Adapter Radio- Navigationseinheit BNS 5.0, Concert 3 35713
    27,126
    Listen to craig, he knows whats he's talking about & I agree with what he says.
    It is strange, if that pic is of the actual adapter set, which allot arent, cause I can see pins fitted in the quadlock for the canbus wires, so maybe its incorrectly pinned & needs moving about, certainly agree though, no need for any simulator, just check your wires pin to pin.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Looking at the quadlock I can see wires in pins 9 & 10 ( can high & low respectively ), but I cannot see any in the center section of the 20 pin mini ISO red connector, so maybe it is just pinned incorrectly.
    Maybe you could post some pics of the harness and we could correct it or you can look at the lid of the Sym II for the correct can bus wires and see if they are in place or crossed even. The quality of some of these ebay cables is pretty rank, I only ever buy Kufatec as you know what you are getting, they very rarely get it wrong.
    Apr 2011
    63
    I only took 2 pictures of my old unit,tommorow i will have pics and from the bns unit.
    Here we go.
    1. View image: DSC00218
    2. Image codes: DSC00219
    Thx for the answers!!!
    27,126
    We mean the adapter set, not the units.
    Apr 2011
    63
    Comin again on this topic as i took a photo of the adapter
    View image: DSC00220
    Hope S8craig or NHN can help
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Show me a pic of the other ends
    27,126
    We're getting nowhere fast here are we lol, ok take pics of the connectors sides of the wires so we can see which colour is going to which pin on the multi connector ends & also on the quadlock end & preferrably in daylight & better clearer pics as those are blurred & for anyone on here to help they need to be as clear as possible.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Looking at the first red connector it does seem to suggest that it has can bus wires on pins 7 & 12.
    27,126
    Yeah but whether the other side of the connector has the correct wire colours is another story lol, only 1 way to be sure I think you'd agree.
