Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Lancaster
    1,788
    RNS-E Showing a fault code.
    Anyone got any ideas over this one?
    I get reception, albeit not very good.
    Thursday,07,April,2011,21:49:46:09484
    VCDS Version: Release 10.6.3 (x64)
    Data version: 20101206
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Control Module Part Number: 4B0 035 192 P HW: 4B0 035 192 P
    Component and/or Version: RNS-E HIGH EU H53 0660
    Software Coding: 0301117
    Work Shop Code: WSC 02335 785 00200
    VCID: 2A50D781FC79
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 3
    Time Indication: 0
    Date: 2011.02.04
    Time: 18:51:09
    Freeze Frame:
    Mileage: 655350 km
    Count: 402
    Clock: 18:50
    To do: None yet.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    It's the diversity system, the A4 is fitted with a diversity on a car your year as long as the original radio had it. So it should not be an issue for an A4, but seems yours is either missing or faulty.
    Do you have both connections on the white antenna socket connected?
    Lancaster
    1,788
    Only got 1 in the back.
    I retrofitted the Rns-e, could this be the issue?
    To do: None yet.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yes of course, do you have the second connector or did you car only have the single antenna?
    27,121
    Had same issue on my B6 years ago when someone retrofitted a RNS-E in place of my RNS-D, the numnuts hadnt connected the diversity at all & thus spent a year with crap radio signals until I got wiser found the loose connector, got the adapter of ebay & voila radio was hell of allot better, guess was beginning of my learning curve into these cars.
    So have a look for 2nd connector if it exists from previous radio.
    Lancaster
    1,788
    My previous radio didn't have a second aerial input? It was a chorus iirc.
    I took out the original, but there was only 1 radio.
    To do: None yet.
    27,121
    Seems elsawin shows week 22 was a change point for the chorus from 1 connection to 2, guessing yours was beginning of 04 then or before?
    Lancaster
    1,788
    Mines a 2001 B6 so must be single?
    To do: None yet.
