JMB RetrofitsAH Fabrications
Results 1 to 7 of 7
    Dec 2010
    7
    A3 2009 Chorus -adding rear speakers
    As this only has front speakers I am looking to add rear speakers.
    Is this as simple as fitting speakers and plugging in? or do I need to install an audi amp & sub?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Amp and sub, wiring and also a new radio (concert II+) to drive the rears. AFAIK the chorus can only drive front speakers.
    Jun 2003
    World of my own
    9,813
    You need the speakers, wiring & sub (as the amp to drive the rears is inside the sub). No Audi HU can drive the rears without an amp. They only have an internal amp for the fronts.
    Alex Turner
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No what I mean by drive is that the chorus II+ cannot even support the amp, it doesn't have rear line levels either. So a concert II+ is required to feed the rear line levels to the amp.
    Jun 2003
    World of my own
    9,813
    No they all have front & rear pre-outs
    Alex Turner
    Dec 2010
    7
    How easy is the wiring, and would a CONCERT( EU AB2 MODEL NUMBER) work ok.
    Jun 2003
    World of my own
    9,813
    Wiring is not easy unless you have the entire rear/sub woofer loom. It needs to run from the boot to the HU and then you need to tie it into a 12v feed. Far easier to just install an aftermarket HU which can drive the rears directly.
    Alex Turner
