Volks AutosSky Insurance
    Chugger
    North Devon
    2,716
    rumble from sub.
    Iv noticed a rumble from my anymac sub when on 0 volume. Is there any distance an amp needs to be away from a speaker because at the moment its fairly close. Other things im considering is the amp is on its way out, or the RCA cable is breaking down ( i have used it in a few installs). Suppose if i disconnect rcas i could eliminate it?? Any ideas from you pro's would be good, cheers
    57 A3 2.0 TDI Sportback (140)
    Jun 2003
    World of my own
    9,813
    Is it running off the stock HU? if so is the feed from the Bose connector?
    The amp can be as close as you like, so it won't be that.
    Alex Turner
    Chugger
    North Devon
    2,716
    no its all running from a alpine unit now andy. Iv used the loom for the remote switch but the amp has dedicated RCA lead from HU. So im thinking it may be the RCA lead, noticed that since i did ther install the bass has been increasing and decreasing randomly, maybe one of the lines is damaged
    Hairy Ballbag's Avatar
    Mar 2007
    West Sussex
    60
    Poor Earth on the amp and poor signal cable would result in that - especially if it happens more on turn on / off.
    Shakey rumble when on and a pop when turned off.
    A humming is usually from interferance, which is normally down to poor quality Phono Leads.
    Chugger
    North Devon
    2,716
    Quote Originally Posted by Hairy Ballbag View Post
    Cheers ballbag.
    It's a constant rumble. You don't notice it until you in the boot with ear by the sub. Turning on and off makes no different noises. I think decent phono's are worth a shot then...
