sportstractor
Chugger
Iv noticed a rumble from my anymac sub when on 0 volume. Is there any distance an amp needs to be away from a speaker because at the moment its fairly close. Other things im considering is the amp is on its way out, or the RCA cable is breaking down ( i have used it in a few installs). Suppose if i disconnect rcas i could eliminate it?? Any ideas from you pro's would be good, cheers
