JMB RetrofitsAH Fabrications
    Jan 2011
    Glasgow
    233
    Headunit Replacing Tape to CD
    My 2000 Audi S3 has the standard tape headunit as pictured below. I would like change it to the CD headunit in the second picture. Do i need to change any wires? or will the standard connectors work?
    STANDARD TAPE:
    Uploaded with ImageShack.us
    CD HEADUNIT
    Jun 2003
    World of my own
    9,813
    Should be a straight swap, but you may find your 2000 model is not CANBUS controlled as they changed on the 2000 plate. In which case the Concert II will turn off after an hour as they are all CANBUS models.
    If you remove the power from the tape player, then plug it back in, if it then says SAFE when you turn it on it is not CANBUS, if it just works then it is CANBUS. Or you can look at the power connector and see if it has a yellow with redstripe wire (switched live) (non CANBUS) or just the red with white stripe (perm live)= CANBUS.
    Alex Turner
    Jan 2011
    Glasgow
    233
    Not sure what you mean mate ive just removed my headunit and im looking to change it to the cd one shown below.... i still can use the cd changer etc?
    Jan 2011
    Glasgow
    233
    please help dont want to buy wrong one?
