Badger5Sky Insurance
Results 1 to 7 of 7
    Mar 2004
    Worcestershire, UK
    48
    Rear Door Speakers in 3 Door (Query for AndyMac)
    Hi Guys,
    I have some 6x9's Infinity 300w Peak output witrh 100RMS, I could do with some advice on an amp for them that will easily fit in the rear door panels such like in andymacs install, would the v12 v400 do the job.
    Also Andy i would like your advice on this install, is there anyway of getting a RCA output from the standard box in the boot, or will i have to run a whole new RCA cables run. Any advice would be great, i've read the your install guide so thats how much i know.
    Any advice from any others would be great, it just seems Andy is the Guru. :-)
    Thanks All
    Jun 2003
    World of my own
    9,813
    Re: Rear Door Speakers in 3 Door (Query for AndyMac)
    Hi Matt
    Yeah you can fit pretty much any amp behind the rear speaker panels in a 3 door A3. There is loads of room in there. I've fitted F400, F407's and there's room to spare. However you are going to be limited as to the sound you can get from that location.
    1. The location itself is not great for a balanced sound
    2. The feebleness of the hardboard door cards (which are only held in place by spring clips) means you can't really get any level of bass from the rear (which is normally the only benefit of big rear speakers).
    If you are amping the rears I would definately suggest amping the fronts as well.
    The pre-outs/remote on are accessible from the loom going to the sub (but only the rears). Pin outs are shown in the instruction manual.
    Mar 2004
    Worcestershire, UK
    48
    Thanks Andy,
    Do you think it's possibly worth doing a cut out into the door card as you have suggested that the Hardboard would get in the way?
    Thanks Again
    Matt
    Jun 2003
    World of my own
    9,813
    Not sure how you'd do that bar building a completely new panel, or building an enclosure behind the panel. Neither of which is an easy task. A sub is a much easier option.
    Mar 2004
    Worcestershire, UK
    48
    Already got the sub. LOL. Thanks for ya help so far i'll let ya know how i get on.
    Thanks Again
    imported_cocain
    If you got a sub already I would forget the 6 by 9 and get some good speakers for upfront mate. Spend your money upfront where you are the most, driving and not in the back. You will have mad hassle to fit them properly in the door card and you will have an air leak. If you do want to replace the speakers in the back get some the same size or at least the same shape and then you can make an adapter ring out of MDF. trust me I've been there.
    good luck
    Mar 2004
    Worcestershire, UK
    48
    Hey Andy,
    How have u managed to mount ya amp in the door?
