JMB RetrofitsAH Fabrications
Results 1 to 9 of 9
    Nov 2004
    Hosrham, West Sussex
    390
    Component install in S3 question
    OK I used the autoleads speaker adapters but the way the speaker sits in the adapter it crushes the outer rubber damping edge of the speaker cone - makes them sound crap!
    What am I missing? Do I need to make some spacers for the screws or do I have the wrong adapters??
    Cheers!
    Adam
    Jun 2003
    World of my own
    9,813
    Re: Component install in S3 question
    No they're the right adapters just wrong make.
    All autoleads products are sh*t, and seem to be designed not to work properly. It's the same story with the speaker adapters they supply for the rears, they leave a 5mm gap all the way round the speaker, or even the fascia adapters that require drastic modification just to actually fit them, then they still stick out and look nothing like the fascia they're supposed to match.
    Best bet is to make your own from 12mm MDF, at least they'll work properly.
    Nov 2004
    390
    [ QUOTE ]
    [/ QUOTE ]
    I'm being a plank here but how would I make a set of spacers from MDF?
    Don't suppose you could chuck a couple in with my stealth sub could you? [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Cheers,
    Adam
    PS: Did you get my cheque ok? Post is crap at the moment [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Dec 2004
    Ruislip, West London
    25
    cut a bit of 12mm mdf that will fit over the hole in the door skin, and cut a hole for the speaker in the mdf.
    attach the mdf to the door skin, and the speaker to the mdf.
    Due to the sturdier mount compared to the flimsy plastic adapter, you will have much tighter and stronger mid bass from the speakers.
    Amit
    darko's Avatar
    Dec 2004
    london, uk
    272
    does anyone have a template for making adapters out of mdf ? I would rather use wood than plastic....
    Oct 2003
    up north...
    767
    i got infinity kapp 50.5cs for my s3, and the cone area is larger than usual for a 13cm speaker - all the available adapters that i tried trapped the cone rubber - i made up my own spacer using mdf to go between the standard plastic adapter and the speaker - worked a treat but needed 6mm mdf sheet, 1/2 hour of time and a jigsaw.
    Nov 2004
    390
    [ QUOTE ]
    [/ QUOTE ]
    Superb, thanks Dunk.
    So in effect I'd be running 2 spacers?
    Cheers,
    Adam
    Naresh's Avatar
    Essex
    260
    To make it easier for you Adam I would first cut the hole in the MDF sheet where the speaker will sit inside. Drill a hole away from the cutting edge to give the jigsaw blade a starting point. Then cut the outer edge of the spacer. It would be impossible to do this the other way around!! [img]/ubbthreads/images/graemlins/blush.gif[/img]
    I'm gonna do this on my next install, and also use the tip on sealing the speaker in the door card! You can also use some dynamat on the door itself around the speaker to help minimise vibration if you want?
    Nov 2004
    390
    [ QUOTE ]
    [/ QUOTE ]
    All sounds like a lot of work [img]/ubbthreads/images/graemlins/smile.gif[/img] lol
    ...will do, have a dynamat door kit sitting at home waiting for some dry weather to take the doors apart again!
    Cheers,
    Adam
