Badger5EM Tuning
Thread: FAO Andymac
    Nov 2004
    Hosrham, West Sussex
    390
    FAO Andymac
    Hiya mate,
    Would like to order one of your stealth sub kits...how do I go about this?
    Already have a Rockford Fosgate 500X amp, I'm guessing 2 of the channels bridged will be enough to drive the sub leaving the other 2 to power some components?
    While I'm here, what is the max mounting depth for front components?
    Cheers!
    Adam
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    Re: FAO Andymac
    mounting depth is 65mm max
    Nov 2004
    390
    Re: FAO Andymac
    [ QUOTE ]
    [/ QUOTE ]
    The Alpine SPRs I like the look of (had a pair of 17cm ones in my old car) are 64mm - too close for comfort?
    Cheers,
    Adam
    Jun 2003
    World of my own
    9,813
    Re: FAO Andymac
    Hi Monty
    Send me a PM on exactly what you need, i.e. do you need the mini loom to plug into the Audi sub loom (so you don't need to pull the head unit, fit the RCA adapter and run RCA's to the back).
    I don't know if the 64mm mounting depth includes the spacer rings needed to fit aftermarket units to the 3 point fixing on the door cards. This does push the speaker back slightly so will require a few extra mm's.
    Nov 2004
    South London
    237
    Re: FAO Andymac
    Andy, what are the disadvantages of tapping into the Audi sub loom with your mini loom - it seems like a lot of saved trouble compared with running rcas down the car. Does the mini loom require the rca to be extended so it can reach the amp, or is it long enough already?
    Jun 2003
    World of my own
    9,813
    Re: FAO Andymac
    The mini loom allows you to plug into the red (or Black Bose) plug once you've removed the OEM sub, at the rear of the car. If you mount the amp behind the rear speaker panel then the mini loom will easily reach the amp.
    The downside is that you are still using the lousy Audi wiring, so there is the possibility of interference on the rear speakers (non Bose only), but when using Alpine V12 amps I've never had this problem, but I know others using other brands have.
