JMB RetrofitsEM Tuning
    AaronMarsh's Avatar
    Apr 2010
    Ipswich
    31
    Aftermarket HU not holding memory :s HELP..
    im sure this has been covered somewhere before but cant for the life of me find any info, basically decided to go for a new JVC headunit for my 2000 A3 8L, Really pleased with the unit but it didnt come with any wiring, no harness etc. so ive managed to connect the headunit with the original audi connectors, everything is working fine but the headunit doesnt want to hold the fact that ive turned off the demo mode and set the correct time every time i take my keys out, for some reason its holding the preset radio stations ive tuned in fine just not the demo mode and time. i know with some wiring looms you have a yellow memory wire that you can switch with another cable to solve this problem but my question is- can you do the same with the original audi connectors? or would it just be easier to buy a new wiring harness, cheers guys!
    Mods: 17" Polished Audi TT Comps, Coilovers, Black leather bonnet bra, H.I.D Conversion, Matte Black front audi emblem, rear wiper/emblem delete
    To Do: Matte Black Vinyled Roof, Facelift Headlights, 18"s or 19"s BBS/Euro!!
    TDIPOWARRR
    Jul 2010
    618
    Swap the red and yellow power wires round and all should be fine.
    Jun 2003
    World of my own
    9,813
    If you haven't used any adapters then you will only have the front speakers working, you need a PC9-410 RCA adapter, this will give you the feed to the rear/sub amp as well as the ISO harness to make th swap on the perm live and ignition live without butchering the Audi harness. You should also wire in an antenna amp adapter otherwise the aerial will have no 12v feed to power the antenna amp,
    Alex Turner
