EM TuningMonster Motorsport
Results 1 to 13 of 13
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    1999 S3 Front door speakers
    Hi All, My passenger door speaker has given up the g after 6.5 yrs loyal service!
    Can someone please tell me if there is a direct replacement ie component speaker i can buy to replace it with? I don't have the bose I don't think but have the stock sub amp etc. I would like to keep the tweeter seperate if i can. Links to ebay etc would be most appreciated!! If not can I get any 4 inch and run the tweeter aswell. Looked at the infinity 4032............INFINITY REF 4032 4" 10CM CAR DOOR REAR DECK SPEAKERS on eBay (end time 17-Nov-10 13:29:05 GMT)
    Bit out of touch these days getting old lol!!
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    Jun 2003
    World of my own
    9,813
    There is no direct replacement other than another Isophon Audi speaker, as the mounting on the door card is non standard. No aftermarket speaker will slot in without an adapter (Pioneer used to do a direct replacement but it is no longer available). Once you have the adapters, which only seem to be available for running a 5.25" driver, then any 4ohm unit will do, but I would go for a component set as the tweeters are gash, so replace these at the same time, they are 1" units and just slot in without any modification.
    Those Infinity's are coaxial which you definately don't want.
    Alex Turner
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    Many thanks for your response!!!!
    Do you know of any suppliers who can supply the adapters and speakers?? I had found the Pioneer set for the TT and A4 on Ebay and Wasn't sure if they would fit the S3??. Oh and do 5.25 fit the door cards?? Sorry to be a numpty but my days of amps crossovers and subs are long gone. I've just pulled the wire off the knackered speaker for now :-).
    Cheers!
    Jun 2003
    World of my own
    9,813
    No the fitment is different on the A4.
    5.25" will fit the doorcard but it needs to be a slim fit, (54mm max depth) otherwise it fouls the window glass when the window is down.
    I sell MDF adapters specifically for the A3 because the plastic Autoleads ones do not fit properly.
    Audi A3/S3 8L MDF front speaker adapters 13cm component on eBay (end time 29-Oct-10 22:58:35 BST)
    Alex Turner
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    Making perfect sense now! I'll have to check out your link at home as the Bay is locked out at work. Any discounts for forum members lol :-)
    If I was planning to keep the car longer I would of took the time for a serious upgrade but It'll be going In the Spring all being well! Time has come for more space and luxury.
    Are the original speakers still available from Audi?? I can get parts at trade -20% so could work out cheapest option for a quick fix.
    Thanx again! your stuff looks ace! If it was 6.5 yrs ago I would of had the sub as well :-)
    Jun 2003
    World of my own
    9,813
    Alex Turner
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    Quote Originally Posted by AndyMac View Post
    Gunna take mine out asap to check what it is and get one ordered!
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    Quote Originally Posted by S3 Dave View Post
    OK took it out and it is BOSE pt no. 8L0 035 411 will this newer part fit??? AUDI A3 S3 A4 RS4 BOSE DOOR BASS SPEAKER 8E0035411A / B on eBay (end time 03-Nov-10 21:02:27 GMT)
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    Just called audi 107 WTF!!!!!!!!!!!
    Jun 2003
    World of my own
    9,813
    Didn't realise you had Bose, they are hard to come by on ebay. Make sure it is actually the speaker, as it is unusual for both woofer and tweeter to blow. The Bose amp that drives them is notorious for dry solder joints on the main PCB, this will cause crackling and distortion especially when the amp is cold. Try swapping the speaker for the other one and see if it is actually the speaker or the amp before going any further. The Bose front speakers are the same as the ones used in the Bose sub so they can handle a lot of power, my money would be on the amp. The amp is in the drivers side cubbyhole in the boot behind the rear lights. You need to resolder the main PCB joints:
    Very easy to do if you are handy with a soldering iron and preferably a solder sucker to remove the old stuff first.
    I have fixed numerous Bose amps in this way. If you get a noticeable hiss when reheating the old solder then that is a good indication of a dodgy joint.
    Alex Turner
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    Nice one Andy! It is the speaker the tweeter is fine and when i took the speaker out it felt scratchy when i moved it! I heated up the lower cone with a hairdryer and moved it a few times and it seems fine at the moment! But i don't think it will last, did you manage to follow that link to the one for 45? I didn't think i had Bose either but i guess the early S3's didn't have the writing on the grills!! Have to see how it goes it aint worth 100 whatever i do!
    Jun 2003
    World of my own
    9,813
    No other speaker fits the 8L (Bose or non Bose), it has to be from an 8L
    Alex Turner
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    Found a Bose Subwoofer on the bay for 15 so i'll just get that and break it. I'll have a spare then aswell!!
