JMB RetrofitsSky Insurance
    ribena's Avatar
    Oct 2003
    Lincs
    75
    main points for changing H/U
    hi
    I've currently got a symphony H/U running a 6ch JL amp connected to components front, rear and sub
    would like more control and info i.e disc times, frequency controls etc?
    am going to install my old kenwood kdc 8080 which still sounds great and don't want to spend extra on a new H/U at the mo
    will be running the amp from front preouts and rear non-fade for the sub therefore bypassing all audi wiring bar the power supply?
    am I right in thinking the things I need to do are :
    1: replace the can-bus live feed so its seperate permanent live and ignition on live
    2: will I need to deal with interference or just install and see what happens (will be running the battery live and phonos on seperate sides of the car
    Feb 2004
    Clearfield, PA
    892
    Re: main points for changing H/U
    with the interference just put it all in and see.. you might find you get none.. or loads..
    then its a case of been a mr homles and investigating why it hissing like ya mams cat!
    Jun 2003
    World of my own
    9,813
    If you are by passing the terrible Audi wiring then you shouldn't have any interference problems. I would recommend grounding the HU with a separate earth (to chassis behind the glovebox) just as a precaution, as I don't know how good the Audi earth lead is. Having said that I have installed 6 HU's in the A3 and only had problems when using the Audi pre-out loom.
