AWEsome GTISky Insurance
Results 1 to 10 of 10
    Allen's Avatar
    Allen is offline 1st Gear
    Jun 2009
    Devon
    181
    Post Thanks / Like
    PC9 404 - Wires dont match up?
    Dont know if i ordered the right one but the wires dont match fitting after market head unit?
    As you can see...
    Any ideas?
    www.Everest4Heroes.com
    **** PLEASE DONATE ****
    Google Adsense Circuit advertisement
    Advertising world
    AndyMac is offline Moderator
    Jun 2003
    World of my own
    9,288
    Post Thanks / Like
    You only need to use 3 of the wires, earth, perm live and switched live. The others aren't used.
    Alex Turner
    Allen's Avatar
    Jun 2009
    Devon
    181
    Post Thanks / Like
    Cheers, but which is which?
    The pins dont match where the wire go though
    b1gdave83 is offline 1st Gear
    Sep 2009
    Mid Sussex
    162
    Post Thanks / Like
    Multimeter will sort that problem out
    A3 1.8t quattro -
    THS high flow manifold, S3 milltek, Forge 007 DV, THS engine mounts, Performance Haldex Controller (blue), Panel filter
    Coming soon - FMIC, Hybrid K03 Turbo, Custom downpipe & high flow cat
    Allen's Avatar
    Jun 2009
    Devon
    181
    Post Thanks / Like
    I've tried them in different combos but still now power?...
    Allen's Avatar
    Jun 2009
    Devon
    181
    Post Thanks / Like
    Think got it sussed apart from the switch live. Which is that?
    Jun 2003
    World of my own
    9,288
    Post Thanks / Like
    On the Audi loom:
    Pin 8 - Earth
    Pin 7 Perm live
    Pin 4 switched live
    Standard ISO layout
    Pin 8 - Earth
    Pin 7 switched live
    Pin 4 perm live
    So the adapter should swap 4 & 7 as Audi wire them back to front.
    However if your Audi is 2000+ then you won't have a switched live on the Audi loom as Audi changed to CANBUS to control this function. So you either pair it with perm live and rely on switching the HU on/off manually or you need to wire one in from the fusebox. The fuse you need is Radio S-Kont.
    Alex Turner
    Allen's Avatar
    Jun 2009
    Devon
    181
    Post Thanks / Like
    Great. Thanks.
    Next issue is rear speakers are not working?
    Jun 2003
    World of my own
    9,288
    Post Thanks / Like
    Rear speakers are separately amped. You need to use the other part of the PC9-404 adapter to link the rear RCA's on the HU to the 20 pin mini ISO connector on the Audi loom, then connect the flying lead on the same adapter to the power antenna lead on the new HU
    Alex Turner
    Allen's Avatar
    Jun 2009
    Devon
    181
    Post Thanks / Like
    All done!! And rear speakers working.
    Just have to turn off by HU and not ignition which is no big deal. Might put switch live in at some point.
    Thanks again for you help
