EM TuningVolks Autos
    Aug 2010
    10
    A3 8L Autochanger question
    Help. I have a space in the boot on top of the sub for a changer. A couple of questions.
    1. Does anyone know the part No. or the code for the CD changer as i have seen some on ebay and want to get the right one.
    2. Will it plug straight in to the multi plug which is also in the boot
    Cheers for any help guys/gals
    Jun 2003
    World of my own
    9,813
    There are only 2 different types, 8 pin and 13 pin, you need the 13 pin, and they are also the most common. The pins on the 8 pin are in a circular pattern (early B5 A4's), the 13 pin are in a square config with only 10 pins actually used. It just plugs into the bus cable in the cubbyhole. If you don't have the fitting bracket then best to use foam sticky pads to secure it to the tupperware sub
    Alex Turner
    Sep 2009
    Mid Sussex
    162
    I have a spare one I could sell you, from 2001 A3 8L quattro
    A3 1.8t quattro -
    THS high flow manifold, S3 milltek, Forge 007 DV, THS engine mounts, Performance Haldex Controller (blue), Panel filter
    Coming soon - FMIC, Hybrid K03 Turbo, Custom downpipe & high flow cat
