Volks AutosAH Fabrications
Page 1 of 2 12 LastLast
Results 1 to 40 of 50
Like Tree4Likes
Thread: Power magic pro running battery down
    AK47UK's Avatar
    Sep 2013
    399
    I installed my DR550GW a couple of weeks ago and since I have found my battery is drained to the point that the engine will not turn over, on both occasions the camera was still recording. I have set my pmp to record for infinity unless the voltage drops below 12v, isn't this correct?
    The reason I want it to record for infinity is so I can capture any damage caused to my car whilst it is left unattended, I thought the point of the pmp was so you could do this but stop the battery from draining to a point where the engine wouldn't start.
    Any tips appreciated.
    8P3 '10 1.8 TFSI 3DR Black Edition S-Line
    Jet2004uk's Avatar
    Sep 2013
    Lincolnshire & Stockport
    282
    Hey AK47UK
    When I had my DR500GW installed it was recomended that I use the "Smart Power Battery Monitor" instead of the Power Magic Pro, I have never had any problems from this and it does cut the camera off when the car battery hits 12v (will only work if camera is in parking mode)
    Audi 2010 A3 2.0 TFSI S-Line S-Tronic Quattro
    AK47UK's Avatar
    Sep 2013
    399
    Does that record continuously until the 12v is reached or for a pre-set time mate? I am paranoid because my car was damaged when in a car park and it looked like malicious damage with intent so I want the camera to always be rolling unless the battery gets too low.
    Jet2004uk's Avatar
    Sep 2013
    282
    I have mine set to motion detect, sensitivity quite high, so in my works car park where people are always coming and going it records 3 min slots all through the day, its not set to record none stop as I find it pointless but it will start recording soon as something moves in to its field of vision
    AK47UK's Avatar
    Sep 2013
    399
    Mine is set to motion etc. I meant that power is provided to the camera permanently so if an event was to occur it would record it. It was my understanding with the timer set to 6 hours that if an event was to occur in the 7th hour then it would not be recorded.
    Jet2004uk's Avatar
    Sep 2013
    282
    I am guessing that the firmware and options maybe different between the models, I asume the hour setting is on the PMP ?
    *edit
    I arrive at work at 7am, When I get home and check the memory card recordings mine has gone all the way through to it capturing me walking to my car at 4.30pm .....so over 8 hours of recording off and on
    AK47UK's Avatar
    Sep 2013
    399
    I have the PMP set to infinity and 12v. On the Blackvue I have used the recommended settings on a youtube vid I watched. The rear cam has its LED on all the time, I turned the front LED off to avoid attracting attention.
    Jet2004uk's Avatar
    Sep 2013
    282
    how long do you think it takes for battery to drain to a point the car wont start? over 12 hours?
    AK47UK's Avatar
    Sep 2013
    399
    Yes, it has only happened twice and both times I think the car hadn't been used for 24 hours.
    Jet2004uk's Avatar
    Sep 2013
    282
    Not taking long then, something drawing a lot of power, just like that Zenec problem I had, I guess you are positive it is the camera doing the draining
    AK47UK's Avatar
    Sep 2013
    399
    I haven't had any power problems since installing the Zenec but a week or so after installing the camera I have had problems so I think the dash cam is the cause.
    Nov 2013
    Heath Hayes
    952
    BlackVue - Full HD 1080p Dash Cameras with GPS
    Looking at the stats maximum power consumption 4.8w . That would be 0.4A or 400mA at 12V . ( 0.4 * 12 = 4.8) .
    Thats a worst case scenario though I would expect something like that to only be taking 100-200mA. The power manager itself will also be using power but I wouldn't have thought that much maybe 20mA . If you add the standing load that the car itself takes which is usually something like 30mA then you are around 250mA.
    Over a 24Hr period thats only 6Ah of capacity but overall the standing load on the car battery is probably about 10 times what it would be without the camera connected.
    So assuming you could reasonably expect the car to be left for 30 days locked with the alarm on before you had an issue, you may only get 2-3 days as the higher standing current will reduce the battery capacity quicker.
    You really need to measure how much current the items are taking to see if the issue is related to the camera or something else with the car.
    The fact that the car is a 1.8 petrol probably means the car battery capacity is smaller than something like a diesel anyway.Also you need to drive the car for a good distance to recharge it, If it's only doing short trips the battery will eventually discharge.
    Karl.
    AK47UK likes this.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    AK47UK's Avatar
    Sep 2013
    399
    Thanks for that mate, my journeys are rarely above 20 minutes long so the alternator might not get a chance to start charging up the battery enough. Might have to bite the bullet and set a timer on the PMP but sods law would be my car would be damaged when the camera was powered off.
    Anthony566's Avatar
    Nov 2013
    North East
    615
    Did you sort this out ?? I have just installed pmp with the BV 550 and so far so good ...
    2013 A4 2.0 TDi 177 quattro Black Edition - Glacier White
    AK47UK's Avatar
    Sep 2013
    399
    I have set the PMP to 24 hours so will test when I don't use my car for a prolonged period, I will be at glasto for a week so that will be the perfect test.
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,114
    I'm watching this with interest. I'm about to get a dash cam
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
    Anthony566's Avatar
    Nov 2013
    North East
    615
    Well so far my PMP has worked as it should ....
    What cut off voltage have you got it set to now ??
    AK47UK's Avatar
    Sep 2013
    399
    12v still, just set the record to 24 hours instead of infinity.
    Anthony566's Avatar
    Nov 2013
    North East
    615
    I have mine set to
    parking mode on in motion detection and 3 min sections
    PMP set to 11.8V and 24hrs
    but when I go to work my shortest run is 80 miles each way ...
    AK47UK's Avatar
    Sep 2013
    399
    Out of interest why did you set to 11.8v? My thoughts were if I set it to 12v there would be more cranking power for my starter motor.
    Jet2004uk's Avatar
    Sep 2013
    282
    When I had battery drain from my Zenec stereo and the volts in the battery got to 10.7v it was not enough to turn the car over, mine is set at 12v
    AK47UK's Avatar
    Sep 2013
    399
    I haven't driven my car for the past few days so today will be the test if the 24 hour on the PMP did the trick!
    Jet2004uk's Avatar
    Sep 2013
    282
    Fingers crossed AK47UK
    Get the jump starter ready just incase lol
    AK47UK's Avatar
    Sep 2013
    399
    Completely dead, no central locking... Still could be the dashcam but now I also suspect the Zenec or a faulty PMP.
    How did you fix your Zenec battery drain mate?
    Jet2004uk's Avatar
    Sep 2013
    282
    They sent me a new unit, fitted the new one and no more battery drain so I deduced it was a faulty head unit
    Jet2004uk's Avatar
    Sep 2013
    282
    AK47UK I found this item handy, gave me a good idea how fast the drain was
    http://www.amazon.co.uk/gp/product/B...?ie=UTF8&psc=1
  28. #27
    Anthony566's Avatar
    Nov 2013
    North East
    615
    I just did a google search and that was the number that came up the most ....
  29. #28
    Jet2004uk's Avatar
    Sep 2013
    282
    Guess a lot of it depends on engine size and type to what size battery you have, obviously diesels take a lot more amps to crank over than a small petrol like mine
  30. #29
    Anthony566's Avatar
    Nov 2013
    North East
    615
    The battery for this car is in the boot which threw me as thats a first for me and its massive !!! Lol
  31. #30
    Jet2004uk's Avatar
    Sep 2013
    282
    In the boot......must admit I never had a car with the battery in the boot, is it that big it fills the boot lol
  32. #31
    Anthony566's Avatar
    Nov 2013
    North East
    615
    I think its used as a counter weight to keep the car level
    Jet2004uk likes this.
  33. #32
    AK47UK's Avatar
    Sep 2013
    399
    Cheers mate, I have a multimeter so will give that a go on the terminals. I think I will disconnect my dashcam for the time being as a test
  34. #33
    AK47UK's Avatar
    Sep 2013
    399
    Think I have cracked it, I followed a guide on here that said to have the switched live on the blower fuse and the perm live on the cigar socket. Since installation no matter which side I switched the PMP multi-boot switch to the green LED remained on which I thought was weird. Just took a multimeter to my car and the blower circuit is a perm 12v so I found a switched 12v (heating / air con circuit) and moved the red wire to there, now the PMP LED switches off and on (although when the green LED is off the rear camera LED is still on). Time will tell.
  35. #34
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,004
    For what its worth, mine is on 24/7 on record / park mode. I don't have a power magic pro, just hardwired in.
    I used to have battery drain issues but it was a faulty canbus in the RNSE. One quick cure by NHN the legend and its all fine and dandy.
    My car sits out the front of my house all week and starts fine at the weekend, so if your battery is draining in a few days, it ain't the cam.
    AK47UK likes this.
    JSD 2.59
    Synergy-Solutions
  36. #35
    AK47UK's Avatar
    Sep 2013
    399
    Is yours the 550 dual cam mate? I didn't realise the battery could power it for so long without running empty and finding out I wasn't using a switched live seemed to explain it.
    Any idea what was wrong with your canbus? I have a Zenec headunit, Jet had a Zenec that caused him drain issues until they replaced it. Perhaps the canbus adapter is at fault but will test my car with the new wiring first.
  37. #36
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,004
    I have the Blackvue DR380 hardwired in.
    The canbus on the RNSE was faulty causing a 2amp drain to earth.
    JSD 2.59
    Synergy-Solutions
  38. #37
    AK47UK's Avatar
    Sep 2013
    399
    Ok cool, I will monitor mine and hope for the best, if it happens again I will investigate the canbus. I'm pretty sure I had left my car for days before installing the dash am without any problems so am hopeful that is the fault. Never experienced this before installing them and had it 3 times since installation.
  39. #38
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,004
    Get in your car and lock it with the fob, keep really still so you don't set the alarm off and if the canbus has gone you will still hear the satnav disc spinning after about 60 seconds as it will keep powered up despite the ignition and the RNSE being off.
    JSD 2.59
    Synergy-Solutions
  40. #39
    Anthony566's Avatar
    Nov 2013
    North East
    615
    Quote Originally Posted by AK47UK View Post
    I know you have sorted out you permanent live and ignition live but I just have a question about how it's working,
    When you have the PMP in the off mode and the ignition is off the green LED should be off and the 550 should be off ... No LEDs on at all, it does take a few seconds to shut down. To test this can you confirm that the 550 gives you the power on voice command when you start the car and gives you the powering down voice command when you turn the car off ??
    I have taken the ignition live from the AC system and when the pmp is off the camera completely powers down when the car is turned off and only stays on when the pmp is on and the pmp green led stays on in this mode.
  41. #40
    AK47UK's Avatar
    Sep 2013
    399
    Cheers for the tip sidibear, my sat nav is held on an internal flash chip but I assume the same goes for an audio cd so will test that. I'm sure when ignition is off something made occasional noises but this was the same with the stock headunit and xtrons too.
    I didn't leave it switched off for long Anthony so that may be why it stayed on. Will also test that by leaving it off for a little while.
  1. Run Battery Flat - ESP Fault
    By SCFC_Messiah in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th July 2012, 20:45
  2. Battery run down again ????
    By dvdk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2012, 19:02
  3. Run / Cool Down on a Turbo
    By brads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2011, 17:25
  4. No power to symphony after battery change.
    By Garrity in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2010, 19:45
  5. power loss after changing battery???
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2007, 22:43
