Revo TechnikJuicy
Results 1 to 13 of 13
    www.badger5.co.uk
    May 2004
    nr Glos
    5,927
    80mm TIP Fitting instructions
    Below is a how to fit a B5 80mm TIP... if in doubt get a competant person to fit this, or alternatively we can fit them for £45+vat
    Firstly remove your original TIP from the car. If you cannot manage this, then please consider getting someone to help fit the new TIP.
    Once tip is removed clean off any oil which no doubt may have accumulated in the TIP and on the outside of the turbos intake. Brake cleaner or such is usefull for this.
    Prep the alloy billet adaptor with a light bead of silicon sealant on its internal diameter as pictured below.
    Have a 2mm allen key to hand to use to secure the grub screw into the turbo's slot. Ball ended are easiest to access. Also, add a small drop of loctite to them just prior to fitting the billet adaptor to both seal and secure it in .
    Slide the billet adaptor over the turbo, (it is usually best to dry test fit this before applying silicon to confirm it slides over nicely). Twist the billet adaptor as you slide it onto the turbo so as to smear the silicon evenly. Orientate the grub screws, so as you look at the turbo, its at 2 o'clock positions for easier access to nip up. Nip up to secure the billet adaptor to the turbo. It should be firm and not rotate.
    Wipe off any excess extruded sealant which has come into the bore. Ensure no silicon is allowed to touch the compressor blades when you wipe off this excess. Once wiped clean, it will look like this. NOTE: There is ZERO step in the flow path to the turbos inlet airflow.... unlike other "copy" products out there.
    Next, trial fit the tip onto billet adaptor to take note of any parts which may need trimming to suit your particular induction setup.
    TIP: the top may need to be trimmed approx 40mm. Check this, as this wil vary between induction kits & Oe airboxes
    N75 outlet will need to be trimmed approx 1/2 its length.
    Use a sharp craft knife for best clean cutting results. TIP use the 70-90 hose clip clamped onto the hose to act as a cutting guide to keep a nice neat trimmed edge.
    Once satisfied the TIP is correct length, fit the lower 70-90 clip onto the TIP lightly nipped so as it wont slide round but not tightened as such with the clip pointing up at 3 o'clock position. See picture below
    Once satisfied its rotated correctly, tighten the hose clip at the lower clip on the adaptor.
    Fit the DV, EVAP, N75 and oil breather pipes to the TIP. TIP use washing up liquid to help slide them on. do not use oil lubricants on these pipes as they may well slide off. I dont ever use washing up liquid or any lube on the large clip onto the billet part. This needs to be tightened and not lubed as again, it could slide off. Note where I have pictured the clip position.. Please do the same.
    Fit the MAF into the TIP, tighten... Check the maf fits the rest of your induction ok..
    Couple of example fitments below.. B5 full kit type install & Neuspeed heatshield + Jr below that
    All should be ok.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    fran-s3's Avatar
    1,090
    Awesome guide thanks Bill. Lastly I hear people warning not to over tighten the jubilee clip on the Jetex filter neck as some have experienced it tearing after a while.
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    890
    Quote Originally Posted by fran-s3 View Post
    like me. silicone sealant has worked a treat though.. for the time being. great write up though I could have done with this a month ago!! haha!
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
    superkarl's Avatar
    MACH 9
    Mar 2010
    Liverpool/Southport. N west
    6,320
    thought id add my experience.
    firsstly after fitting the billet adapter i just could not get the TIP to sit tightly over it. in trying to get to the jubilee i was bending the TIP to get to it which was popping the TIP off, no matter how tight i got that clip, it would eventually slide off...WITH sealant on the tip-adapter! i was using a variety of screwdrivers mind, not ring spanners (didnt have one so small).
    so what I did, was work out my 2 + 4 o'clock position of the grub screws, and also work out where the tip would be and what angle (pushing the parts on and mocking up doesnt take long, just visualise where the maf/filter would be and what angle), and put the TIP on the adapter, off the car. tightening the jubille as tight as i could pretty much. it was snug, no sliding off the adapter.
    i then put the whole lot on the turbo, making sure the grubs were at there 2+4 oclock positions. i could get to them with the 2mm allen key by bending the tip out the way (it wont pop off the adapter anymore).
    then its all tight and ready for the DV, N75, breather + esp.
    Now i started this job at 1 o'clock. by 4 o'clock it wasn't fitted because of my trouble getting the bottom jubilee tight without the tip sliding off (i did do a couple other jobs while i was down there but still)
    after changing the assembly procedure i had it fitted and tight in about 30 minutes. i was incredibly frustrated having taken 3 hours to realise.
    whilst doing it i imagined that the V1 TIPs would have been a hell of alot easier because they are 3 piece. but the 1 piece was tricky as its so big.
    just a heads up for anyone encountering problems. hope it helps.
    1873bhp - 1567lbsft
    0-60 1.73sec - 1/4mile 4.24sec - top speed 267mph
    Honest
    www.badger5.co.uk
    May 2004
    nr Glos
    5,927
    Never had issue on sliding the tip onto the billet piece. they dont slide off when slid on fully.. they simply cant. loads of land for them and the clip when pushed on fully. I dont advise using washing up liquid on this piece, but it would help, BUT you would need to allow time for it to dry off before tightening the clip else I imagine it would then slide off much easier.
    Flexi head 7mm hose do a upper is handy or small 1/4 drive ratchet with 7mm socket is what I use
    bill@badger5.co.uk
    www.badger5.co.uk
    May 2004
    nr Glos
    5,927
    yep.. dont tighten the JR's clip too tight no.. Its thin and can (and has) cut into the neck of some filters. The "feel" from some of the clips is'nt great. So long as its tight and wont slide off (which is pretty much how it is when slid onto the maf without clamp) its on well enough for just a little extra clamping from the hose clip.
    bill@badger5.co.uk
    superkarl's Avatar
    MACH 9
    Mar 2010
    6,320
    Trying to access the clip I was pushing the tip out of the way which was levering it off the adapter.
    But as you say a 7mm socket or ring spanner and my arm wouldn't have been in the way like when trying to use a screw driver.
    In the end though I did it very quick putting the tip and adapter on assembled.
    If I was to do it all again I'd say u could do it in an hour.
    1873bhp - 1567lbsft
    Honest
    www.badger5.co.uk
    May 2004
    nr Glos
    5,927
    it take me an hour so sounds spot on.
    bill@badger5.co.uk
    Apr 2012
    14
    How large is the difference in airflow between the Jetex filter and the OEM air box with a green filter?
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    265
    No trimming for oe airbox?
    i beg to differ!
    ive had to take 20mm off the turbo inlet side of the hose and the hose STILL kinks when squeezing it back to it over the airbox!
    80mm all the way through.. then it kinks and is no better than standard!
    unless i have a dud hose aswell as the adaptor!
    nothing fits with this hose.. everything is well off!
    I cannot fit this without it kinking!
    www.badger5.co.uk
    May 2004
    nr Glos
    5,927
    edited the instructions now to confirm trimming
    bill@badger5.co.uk
    Nov 2011
    136
    sorry if this is the wrong place, but i have just bought one of these, off a member and it doesn't have a jubilee clip for the N75 one, what size clip do i need for this?
    Thanks.
    James
    Oct 2011
    41
    Just an update really. When your doing up rubber/silcone hoses and you need some lube, I find a little bit of hair spray works a treat ! And when it dries it gets a right good grip/seal (old trick we used to use for putting grips on bmx bikes ;-)
  1. Replies: 47
    Last Post: 27th June 2012, 14:08
  2. Badger5 80mm TIP, Jetex & Heatshield.
    By JtotheD in forum Badger 5
    Last Post: 20th December 2011, 22:05
  3. 3" Downpipe - Fitting Instructions?
    By Piester in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2011, 00:06
  4. armrest fitting instructions
    By Matt_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd August 2010, 22:42
  5. Brake pedal switch - fitting instructions ??
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2010, 22:25
