AH FabricationsEM Tuning
    RIP S3dave
    May 2004
    nr Glos
    7,139
    why large bore intakes such as B5 one work... on IHI's also 55g/s gains
    Car in question came in with an ihi vf34 turbo kit on it, done by a.n.other company.
    .. started addressing the TIP..
    As it arrived, remembering it was previously a k03 tip with glued on silicon to upsize it to the vf34's much larger intake..
    3" Billet adaptor, custom TIP manufacture begins.
    Mock up... ready to machine to VF34 dims
    mocked up intake
    [/QUOTE]
    remember this vf34 was having to breath thru a small inlet... for k03!!
    before decent size tip airflows below:
    Code:
    Group A:	'003				Group B:	'020				Group C:	'118
    	RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Temperature	Load	Absolute Pres.
    TIME					TIME					TIME
    STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	°C	 %	 mbar
    154.51	1720	27.28	100	21	154.81	0	3	0	0	154.21	1720	24	88.6	1050
    155.41	1720	28.22	100	22.5	155.71	0	3	0	0	155.11	1720	23	94.5	1110
    156.31	1920	32.25	100	9	156.61	0	3	0	0	156.02	1760	21	92.2	1150
    157.21	2320	45.36	100	15.8	157.52	0	3	0	0	156.91	2200	21	94.1	1220
    158.11	2720	58.69	100	12	158.41	0	3	0	0	157.81	2600	21	95.3	1380
    159.03	3120	79.08	100	9	159.33	0	3	0	0	158.71	3000	21	95.3	1540
    159.91	3600	116.17	100	6.8	160.21	0	3	0	0	159.61	3440	21	95.3	1840
    160.81	4280	194.64	100	5.3	161.12	3	3.8	0	0	160.51	4000	24	83.5	2510
    161.72	5120	219.19	100	8.3	162.02	3	3.8	0	3	161.42	4920	27	84.7	2540
    162.62	5520	213.53	100	11.3	162.92	3	3.8	0	3	162.32	5440	30	83.9	2540
    163.51	5720	215.83	100	9.8	163.82	3	3.8	0	3	163.22	5640	34	82.4	2530
    164.42	5960	216.22	100	9.8	164.71	3	3.8	0	3	164.11	5880	37	80.8	2490
    165.31	6160	215.75	100	13.5	165.61	2.3	3	0	2.3	165.01	6080	40	80.8	2450
    166.21	6400	215.25	100	11.3	166.51	2.3	3	0	2.3	165.91	6320	45	81.6	2440
    167.14	6680	215.44	100	10.5	167.42	2.3	3	0	2.3	166.81	6600	48	82.4	2410
    168.01	7000	216.22	100	13.5	168.31	2.3	3	0	2.3	167.72	6880	51	84.7	2370
    and after making/fitting a decent intake to the turbo so it can breath properly
    Code:
    Group A:	'003				Group B:	'020				Group C:	'115
    	RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Absolute Pres.	Absolute Pres.
    TIME					TIME					TIME
    STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	 %	 mbar	 mbar
    14.7	1680	29.31	100	21.8	14.99	0	0	0	0	14.39	1680	82	1410	1030
    15.59	1680	30.72	100	19.5	15.89	0	0	0	0	15.29	1680	94	1450	1090
    16.49	1840	34.5	100	10.5	16.8	0	0	0	0	16.19	1720	97.7	1460	1150
    17.39	2240	46.78	42.7	16.5	17.69	0	0	0	0	17.09	2120	103	1410	1220
    18.29	2640	58.83	37.3	12.8	18.59	0	0	0	0	18	2520	110.5	1380	1350
    19.19	3040	81.44	100	9	19.49	0	0	0	0	18.89	2920	126.3	1980	1470
    20.09	3520	115.42	100	9.8	20.39	0	0	0	0	19.8	3360	157.1	2180	1770
    20.99	3960	153.44	100	12.8	21.29	0	0	0	0	20.69	3840	190.2	2190	2150
    21.9	4440	178.72	100	10.5	22.18	0	0	0	0	21.6	4280	191.7	2180	2290
    22.8	4840	193.94	100	14.3	23.1	0	0	0	0	22.49	4720	191.7	2180	2290
    23.69	5200	204.83	100	13.5	23.99	0	0	0	0	23.39	5040	191.7	2230	2270
    24.6	5600	220.53	100	12	24.89	0	0	0	0	24.29	5440	191.7	2330	2280
    25.49	6000	254.53	100	11.3	25.79	0	0	0	0	25.21	5880	191.7	2400	2370
    26.4	6440	261.28	100	13.5	26.7	0	0	0	0	26.09	6320	191.7	2430	2440
    27.35	6760	265.75	100	13.5	27.7	0	0	0	0	27	6640	191.7	2440	2450
    28.3	7120	274.5	100	13.5	28.6	0	0	0	0	28	7000	191.7	2460	2440
    29.19	7400	274.5	99.6	13.5	29.49	0	0	0	3	28.89	7320	191.7	2450	2440
    30.09	7800	272.72	41.2	18	30.39	0	0	0	0	29.79	7600	190.2	2480	2440
    Peak figure gains: previous highest airflow 219g/s @ 5000rpm @>1.5bar boost
    Current airflows with badger 5 made 3" intake is 274g/s @ 7000rpm @1.4bar boost
    55g/s gains!!
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    beachbuggy's Avatar
    Surrey
    1,741
    Wow that's impressive £ per bhp that has to be one of the best mods available. Just goes to show what having the right additions to a BT makes!
    RIP S3dave
    May 2004
    nr Glos
    7,139
    the other side of the coin is not to restrict an IHI turbo by impeding its flow by sticking a TIP for a k03 onto it.. which when you say it out loud, is pretty silly. Why would someone do that?
    bill@badger5.co.uk
    sambryant's Avatar
    seat leon cupra r owner
    May 2011
    bristol
    158
    very impressive bill :D
    the other tuning company should be ashamed of there work
    BADGER 5 TUNED gt2871, 360bhp 360ftlb
  1. Intakes for a Diesel?
    By Maq in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th June 2010, 15:25
  2. Intakes
    By Shane. in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2010, 22:18
  3. Large bore inlet? on a 1.8t aum
    By will.f_1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2010, 13:59
  4. anyone ever fitted a miltek large bore downpipe???
    By MAD_Adamski in forum Diesel forum
    Last Post: 3rd May 2009, 00:47
  5. Work in progress pics (large download)
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th October 2003, 11:29
