EM TuningJMB Retrofits
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    Badger5 80mm TIP, Jetex & Heatshield.
    Just had a technician at work fit mine for me, and he comes back and says he had to disconnect the coolant pipe to get it all in properly, he's obviously fitted it all back together and for my brief drive down the road the car drives fine, but is this normal or should I be checking for anything he may have done wrong? Thanks Josh
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
    Nov 2011
    Central Scotland
    160
    just fitted mine and finished 10 minutes ago never had to remove any coolant pipes only pipes that go in to the new pipe.
    little grub screws were tight to get to but once they were in all went a lot easier
    i would just check around everything is tight and no leaks but your mechanic should have done all that for you
    JtotheD's Avatar
    Events Moderator
    May 2011
    907
    Yeah I'm sure he's done it okay, thanks for the info.
    check it out!
    RIP S3dave
    May 2004
    nr Glos
    7,195
    He did'nt need to disconnect any coolant pipe. No idea why he thought he needed to do this.. At best a slight tweak on it is all that would ever be req'd.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    JtotheD's Avatar
    Events Moderator
    May 2011
    907
    oh okay, well everything is working fine and no issues except he also tightened the clip too tight on the jetex flange and so it has ripped slightly. any ideas on a decent fix besides ductape? I've heard some people have made a custom extension bracket out of slilicone hosepipe and some grip clips..?? thanks
    check it out!
    RIP S3dave
    May 2004
    nr Glos
    7,195
    Quote Originally Posted by JtotheD View Post
    not much you can do if he's tightened the clip so tight as to bite into the rubber.. no need of dong that
    www.badger5.biz
    bill@badger5.co.uk
  1. Replies: 47
    Last Post: 27th June 2012, 14:08
  2. BMC 80mm Open Cones now Available from Badger5
    By badger5 in forum Badger 5
    Last Post: 11th January 2012, 17:02
  3. FOR SALE my BADGER 5 3 INCH TIP & JETEX FILTER
    By tjkherz in forum For Sale/Wanted - Audi Parts
    Last Post: 4th August 2011, 07:59
  4. Badger5 TIP & JC Filter on Friday :)
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2011, 16:17
