1.8T & 2.0TFSi Specialists
Backdraft Transverse 1.8T Big Turbo Base kit
For those of you wanting to build your own big turbo kit for the 1.8T, we are now providing a sound base for you to start.
Our BDM18T base kit includes the following-
BDM Cast high flow turbo manifold
Garrett GT2860RS ball bearing turbo
Stainless Steel Braided oil feed hose
SS Braided oil retun hose
SS Braided Water feed hose
SS Braided Water return hose
Top oil drain flange
SS Lower oil drain pipe
SS Oil feed restrictor banjo bolt
Banjo bolts & copper washers
SS Manifold studs
12mm M8 copper split nuts
SS M8 washers
Actuator bracket and extension rod.
Gasket kit
Just £1995 including VAT and UK mainland delivery
Kits are in stock and can be with you within 2-3 days (Mainland UK)
Kits are available to be shipped world wide. Please ask for shipping costs.
All other elements of our kits are available individually for different car models and performance requirements. We provide full technical support. Flanges and stainless steel pipe, bends and reducers. Sports cats and race cats. Injectors, Fuel pressure regulators, fuel pumps, forged conrods, low comp pistons etc etc.
When you complete your own kit, you can bring it to our workshop for a check over. We can supply remapping and rolling road testing.
We are an approved distributor for Garrett, so we can provide almost any turbo in the vast range. You can substitute the GT2860RS listed above for the GT2871R for an additional £100 plus VAT.
Best Regards
Mark
Backdraft Motorsport
01908 821216
