    Backdraft Motorsport's Avatar
    1.8T & 2.0TFSi Specialists
    Sep 2007
    206
    Follow Backdraft Motorsport On Twitter Add Backdraft Motorsport on Facebook Visit Backdraft Motorsport's Youtube Channel
    2.0TFSi roller bearing fuel pump drive upgrade
    BDM are proud to offer a roller bearing fuel pump drive kit upgrade. This kit is a truly ‘fit and forget’ solution to the high maintenance, problematic OEM fuel pump drive system.
    The OEM fuel pump is driven by a flat faced follower running off the cam shaft lobe. The problem with this design is that it’s simply overloaded and causes increased friction which accelerates wear. This causes cam follower, cam shaft and fuel pump failures and in some cases the damage is irreparable.
    But now with the roller bearing fuel pump drive kit, the worry of fuel pump follower issues are a thing of the past.
    Roller bearing follower & reprofiled camshaft lobe
    On the left is the OEM cover. On the right you can see the modification to accept roller bearing.
    The inside view of the roller bearing.
    The OEM camshaft lobe (pictured on the table) is also replaced for a newly profiled lobe.
    This upgrade works on K03 & K04 variant motors, early camshafts, late camshaft and schrick aftermarket camshafts.
    For more details please contact us.
    Steve @ BDM
    Milton Keynes VAG Independant Specialist
    Phone: 01908 648081 / Email: info@backdraftmotorsport.com
    warren_S5's Avatar
    Oct 2007
    7,134
    Very very interesting. As someone who has suffered a fuel pump internals ovalisation with an early model KMD internals this hasn't come soon enough!
  1. Replies: 8
    Last Post: 7th October 2012, 12:12
  2. 2.0TFSi - Upgraded Fuel Pump Link
    By Spin140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2008, 09:13
  3. fuel pump upgrade
    By outlaw in forum Tuning
    Last Post: 20th May 2007, 21:18
  4. Fuel Pump upgrades
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2006, 20:35
Tags for this Thread
