Chris NottJMB Retrofits
    S38P's Avatar
    Istanbul, Turkey
    130
    corner weight question
    hi all,
    I scaled my s3 and the results are hereunder
    LF 464 423 RF
    LR 268 272 RR
    CROSS 691 48,42%
    LEFT 732 51,29%
    REAR 540 37,84%
    TOTAL 1427
    *all weights are in "kg"s.
    I have some questions;
    1) i learned that i have to disconnect the sway bars while weighing. will it effect the results dramatically? should i repeat the weighing with the sway bars disconnected?
    2) are the weight differences too much to align from coil overs?
    i will really appreciate if you can give me some advise
    thanx in advance..
    APR Stg3 GT2871R|APR HPFP|APR FMIC|Ported&Polished head with +1mm valves|Forged Build Engine|Gredddy catch can|oil filter relocation+oil cooler|Braille Battery|SACHS|SMFW|Forge shortshifter|VF Engineering motor and transmission mounts|APR DP+test pipe+Supersprint rear silencer|HR ARBs|KW V3s|HALDEX Controller|8 pot RS4 Brakes|18x8 ET45 Ultraleggeras (Matt Graphite Silver) |225/40/18 Advan A048|SPARCO Evo2 Seats with 4point harness|rear seat delete+stripped interior|Defi Boost & EGT|AEM AFR|
    Mar 2012
    52
    You should disconnect the Sway bars yes. It can have a big impact. You will be able to level that out via coilovers, however, it depends how level you want the ride height.
    Have a look at my project thread, My LCR was corner weighted.
    Backdraft Motorsport's Avatar
    1.8T & 2.0TFSi Specialists
    Sep 2007
    206
    Follow Backdraft Motorsport On Twitter Add Backdraft Motorsport on Facebook Visit Backdraft Motorsport's Youtube Channel
    You do need to disconnect the anti roll bars to corner weight the car. If you have significant difference in height from one side to the other, then you will need adjustable drop links to even out the pressure.
    Your percentages front to rear don't add up... is that a type error? total should add up to 100%.
    It is really difficult to balance a road car from one side to the other and keep the ride height reasonable. You can really effect bump steer also by running the geometry uneven. Try getting the 2 fronts as even as possible to help with braking and front wheel traction.
    Also make sure your set up is perfectly flat with floating platforms. Without this it will be pointless.
    truth is, corner wieghting really isn't a DIY job as you can really affect other areas of geometry if you aren't careful. We use a hunter 4 wheel alignment system with level/floating platforms.
    Steve @ BDM
    Milton Keynes VAG Independant Specialist
    Phone: 01908 648081 / Email: info@backdraftmotorsport.com
  1. Oil weight question.
    By jonbonazza in forum TT/TT-S/TT-RS Forum
    Last Post: 6th May 2010, 20:57
  2. s3 corner weights ?
    By kek700 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2010, 12:18
  3. What is around the corner?
    By spencerjoel in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2010, 14:41
  4. Wheel weight and unsprung weight info
    By dunk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th October 2009, 18:30
  5. Question about weight
    By powerplay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2006, 15:18
