Hi All
Awesome have managed to agree a GB of the new Forge SplitR valves
We have a limited supply for the GB and this will be accross all the VAG forums that we advertise on
The prices for a minimum of 10 will be £90.00 + VAT (£105.75 all in)
Postage on these will be £10.00 + VAT (£11.75 all in)
These are the only atmoshereic dump valve that can be used on the 1.8T engine in the VAG cars without bringing on any warning lights or putting the engine in to limp home mode
Here is the info :-
The Splitter is a truly remarkable valve that gives a combination of blow off and recirculation valve operation all at the same time and has been specifically designed for the many VAG 1.8T applications. This means you get all the noise of the blow off valve whilst retaining the compatibility with the recirculation requirements of the engine management system. As a bonus we also offer the ability to convert the valve to recirculation only mode for those times when stealth running is required.
This valve uses a Copper and Zinc alloy piston which utilises new sealing technology along with a variable spring preload incorporating a ratchet type top adjuster that will allow for the positive and precise adjustment to match the valve to your engine. This is achieved by using a unique single, conical, progressive rate spring that can allow for the retention of boost pressure over a wide adjustment range. This unique spring design also allows for unrestricted piston travel and flow volume regardless of the amount of pre-load adjustment added to the spring. Other manufacturers valves using cylindrical springs with adjustable pre-load often experience restricted piston travel and a reduction in flow volume.
When we say our products are Engineered For Performance. Its not a catchy sales phrase, it's the truth and we prove it with every product we manufacture.
These are only available in polished
Please put your names down if you are interested and when we have the 10 names required for the GB we can start the ball rolling
Thank you all for taking the time out for reading
Sarah
