Sky InsuranceBadger5
    likes his V6
    Sep 2007
    North Wales
    55
    Wynn's engine purge - will it stop my exhaust tips blackening.
    Hi,
    I did try and send this through the form on your web site but the captcah seems to be borked.
    I am noticing that the exhaust tips of my S4 seem to blacken quite quickly (when i took delivery of it - used car - the tips where completely black and took some scrubbing to bring them back to shine). Does this indicate that my engine could use a purge - would it likely stop this problem?
    Dec 2008
    227
    Hi there,
    As far as I'm aware it probably wouldn't help a great deal.
    Although the engine purge would clean up the engine internally, the problem with the tips blackening is to do with the un-burnt fuel in the exhaust gas mixture.
    It's pretty much normal for exhaust tips to 'soot up' however if it's doing it faster than you would expect then it could be an underlying issue causing a possible over fuelling of the engine.
    Hope this helps,
    Regards, AL.
  1. Will a s3 milltek exhaust fit a 1.8t?
    By nealb in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2011, 20:52
  2. Will an B7 RS4 exhaust fit a B7 S4??
    By Abb in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th June 2011, 23:51
  3. a3 2.0TDI (140) - will a 170HP TDI exhaust fit???
    By carty80 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2009, 19:06
  4. Will a transverse K04 exhaust manifold
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2009, 12:29
