AH FabricationsVolks Autos
Results 1 to 7 of 7
Thread: Help please!
    Newcastle
    Help please!
    Ok so im wanting to buy some new alloys and have seen a couple of sets I like including these off fleee bay, problem is i have no idea about cars lol
    will these fit ? they are 20" 5 stud tyre size 235/30/20
    pcd is 100 and et35
    here is the car they will be going on 2009 audi a4 sline
    Many Thanks
    Aarron
    Big Bird's Avatar
    Mar 2010
    81
    Not sure if they'll fit or not, but i think it'll make your ride interesting.........
    2009 A4 Avant, 2.0T Quattro S-Line, 19" alloys, B&O audio, Satnav, Reversing camera, Milano leather, misano red, light pack, heated seats, bluetooth phone prep
    Honda VFR 800 VTEC - Italian Red
    pns2007's Avatar
    Nov 2008
    627
    There are two other factors which you need to consider. The first is the bore size of the wheel (centre hole), most early Audis have a bore size of 57.1mm whereas the B8's have a bore size of 66.56mm now. The second is the width of the wheel 8J, 8.5J or 9J. I also think the bolt pattern on the B8 A4 is 5 x 112 and not 100 (PCD). Therefore I dont think the wheels you refer to will fit, but you could try posting on this thread for some help:-
    http://www.audizine.com/forum/showth...4-wheel-setups
    See also this thread:-
    http://www.audizine.com/forum/showth...highlight=bore
    I think you will also need to give you suspension set up in your posting
    Neil
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    Newcastle
    Thanks for the replies guys, will have alook on that forum.
    Crazyfool's Avatar
    Lead boot
    Feb 2007
    South East
    623
    It looks like you have the same wheels as me, so presume you are currently running on 18's. If you are, there is a possibility your car is lowered by 30mm from the standard spec. What I understand from reading other threads is that the car can only be lowered by 20mm if you want to run on anything bigger.
    (59) 2.0T A4 S-Line Avant (B8) Lava Grey
    (N) 2.6 V6 Audi Convertible Europa Blue
    Gone: (02) 1.8T A4 sport saloon (B6) Denim Blue
    Newcastle
    yeh mate i have 18"s on at the mo, so ive went for my 2nd choice of wheels set of 19" finich firenze's just need to pick between black or silver lol.
    thanks for the replys
    TOON FLYER's Avatar
    Sep 2009
    Newcastle
    23
    Aarron
    Like Crazyfool has mentioned check how much your car is lowerded as they may rub. I would go for black
