Results 1 to 9 of 9
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    How to make handbrake in B8
    yesterday I went for track to check how my car good is.
    LSD is great, it's my first audi which is easli going sideways.
    But there is a huge problem when you want make U turn, it's not a problem doing it with scandeniav flick...
    But when it is not many space without handbreak it's inpossible.
    Is it possibility to do something with butto-handbreak, so it will be working faster?
    2005 A3 2.0TDI S-line quattro
    2007 S3 silver 300Hp
    2008 S3 sportback SprintBlue: Bucket seats, magnetic ride, RNSE, BOSE, Bluetooth, Carbonspeed CAI, Forge BOV... SOLD
    2009 A4 3.0TDI Ibis white with some goodies
    2011 S5 Sportback Sepang Blue with Milltek Race Exhaust
    scoTTy's Avatar
    Essex, UK
    1,958
    I guess it doesn't swing the back out as it brakes all four wheels :
    "If you pull out and hold the parking brake switch at a road speed above about 8 km/h, this will initiate an emergency brake application. The brakes are then applied hydraulically at all four wheels. The effect is the same as an emergency stop (full brake application)"
    p.s. Since when do you need this on track? It's not a rally stage ! :D
    MY2010 B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    It's a daily car, but when it's a lot of snow I like to drift on snow a bit and then I need handbreak
    scoTTy's Avatar
    Essex, UK
    1,958
    You may like this video of me playing in my old S4 with the occasional use of handbrake
    I like the 0-100mph in it
    http://video.google.com/videoplay?do...ty(uk)+s4+snow#
    p.s. If the embedded video doesn't work then just click on the link in the header
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    too much donuts I have a Headake
    Dec 2009
    23
    I know it is possible to raise the speed limit of the handbrake via vagcom. But don't know how much
    Aug 2009
    169
    An all new most ridiculous thing i have heard. IF you could get the electronic brake to operate whilst driving it would never lock and unlock fast enough. If you can drive and have enough power then you wont need a handbrake. As already mentionend these arent rally cars, maybe trackable but rally no.
    S3, 4 wheels, magical B8's, Eibach, Pipewerx equipped, glass windows, metal engine, silver paint.
    27,126
    Problem you'll find is, because the brake is electronic, its got built in safety systems as such so it will never work the same as a manual given they were cable controlled anyway, these ones are electric motor driven with probably sensors/microswitches that react in conjunction with the other car systems, you'll never get the same effect purely from a safety POV, but wasnt this obvious tbh???
    The handbrake switch is a signal electronically now, not any cables so effectively if the car detects you're turning or driving at speed it probably wont allow things to work or activate quickly, common sense prevails I would think.
    gr1zly's Avatar
    Nov 2007
    Poland, Cracow
    207
    Ok few test done, with audi drive select switch to dynamic, and wet road car is drifting very easly, soon I will make some movies
